No spark from the packs - TCCoA Forums
post #1 of 8 (permalink) Old 11-10-2007, 08:49 AM Thread Starter
conradcliff's Avatar
Hey guys, long time no see, it's good to be back on and see everything is going strong...On with the question:
So, about 5 months ago I bought a '96 Mark VIII that is running pretty good..My T-bird was still running when I parked it and it started up ok about 3 months ago or so, but this morning when I tried to crank it up the battery was dead. Well, that was no big surprise; I jumped the battery for a while and went out to start it up but it just turns over and over without firing at all. I checked to see if any fuel was getting to the fuel rail by opening that little valve and some fresh looking gas poured out of it, so I had my nephew turn the car over while I held one of the plug wires close to a ground to see if there would be an arch...there wasn't. Any ideas as to what the problem may be?
Thanks for any help!
conradcliff is offline
post #2 of 8 (permalink) Old 11-10-2007, 09:30 AM
Gcline's Avatar
Try wiggiling the connector for the crank sensor by the AC compressor. Mine did the same thing, only had to mess with it once like a year ago, havent done it again since
Daily Driver, 38mpg!
Gcline is offline
post #3 of 8 (permalink) Old 11-10-2007, 09:37 AM Thread Starter
Thanks for the quick reply! Will do!
post #4 of 8 (permalink) Old 11-10-2007, 10:07 AM Thread Starter
Eureka!!!!!!!! you are awesome sir!
This is for you! (turn your speakers on...)
post #5 of 8 (permalink) Old 11-10-2007, 10:14 AM
Gcline's Avatar
haha thats awesome!
Glad it wasnt something serious, dunno why it does that, and a simple wiggle fixes it.
Gcline is offline
post #6 of 8 (permalink) Old 11-10-2007, 10:18 AM Thread Starter
Thanks again!
post #7 of 8 (permalink) Old 11-10-2007, 01:23 PM
Amateur Expert
Embalmer's Avatar
Send a message via AIM to Embalmer
The dreaded CKP harness ghost strikes again! About 5 years ago I had the same problem and someone told me to try that same solution. Apparently, without a signal from the sensor, the EEC will never fire spark because it doesn't know what position the crank is in.
2007 Ford Mustang GT Premium - SOLD March 2014.
2013 Ford Taurus SHO (TUXESHO) Tuxedo Black Bone stock for now.
Embalmer is offline
post #8 of 8 (permalink) Old 11-10-2007, 02:01 PM
The first clue that the crank sensor is not working is that the tach won't move when you try to start it. Without a signal, the PCM has no clue the engine is even turning.
