dohc connecting cooling system - TCCoA Forums
post #1 of 7 (permalink) Old 11-12-2007, 05:31 PM Thread Starter
Send a message via AIM to AtroXR7 Send a message via Yahoo to AtroXR7
Ok I've finally gotten around to finishing my 96 mark engine swap into my 96 cougar. I pretty much have everything buttoned up but some vacuum lines, coolant plumbing, and some tranny cooler plumbing. The vacuum shouldnt be a problem once i get mitchell out. The cooling system has me hung up tho. I've tried searching but im suddenly having a hard time finding all the swap threads.
So anyway, does the mark have a different coolant reservoir? more like the mustang one maybe? I can get all the mark hoses to connect to the tee, but what i assume is the reservoir line... its 3/4" from the tee and 1" at the reservoir. What did you guys do to fix this? I was gonna get some 1" line and just tighten it down to the 3/4" but i cant find 1" line anywhere... Next stop is gonna have to be home depot to see if i can make something there work.
AtroXR7 is offline
post #2 of 7 (permalink) Old 11-12-2007, 08:00 PM
From what I remember, the Mark 8 reservoir to T-stat housing hose had a larger formed end for the reservoir end.
You might try seeing what formed hoses your local auto parts store has behind the counter.
-Rod
post #3 of 7 (permalink) Old 11-12-2007, 09:09 PM Thread Starter
thanks rod, i checked other hoses in stock... nothing close to the right shape. A buddy told me his shop gets 1" hose from NAPA, so ill try them i guess... I find it odd you cant even order that res. hose... I guess i should triple check that thomas didnt send me one with the engine
AtroXR7 is offline
post #4 of 7 (permalink) Old 11-13-2007, 08:39 PM Thread Starter
for anyone that searches this, yes napa carries 1" heater hose. I'll probly just by a 1" to 3/4" reducer from lowes and go that route
AtroXR7 is offline
post #5 of 7 (permalink) Old 11-15-2007, 01:54 PM
^^ How'd you make out? I might have to do this same thing.
Thanks.
mercenvy is offline
post #6 of 7 (permalink) Old 11-19-2007, 09:54 PM Thread Starter
ehh, i didnt like it, took too much hose to make the bend and it was too prone to kinking, I just hacked the res. part of my sohc lower hose off and used it. Not the way I wanted to go, but oh well, it worked. Id honesly suggest checking the ford dealership for the right hose. Or of course a donor car.
AtroXR7 is offline
post #7 of 7 (permalink) Old 11-20-2007, 02:15 PM
Thread Killer
midwestbird's Avatar
Can you post any pics because I dont remember having this problem.
As of 10-20-06 DOHC POWERED
Painted Vista blue as of 08
242hp/251tq
[email protected] [email protected] Byron Il
RobertP plate modded: 5-23-08
midwestbird is offline
