Parking shift lock question - TCCoA Forums
post #1 of 6 (permalink) Old 07-30-2002, 10:00 AM Thread Starter
96_4.6_MN12's Avatar
Unhappy Parking shift lock question
Yesteday I was helping my bro install an amp and a new deck. After everything was done, the following occurred with the car:
1) wouldnt shift out of park, even with brake pressed. (OD button works ok)
2) rear lights, including 3rd light dont work when pressing the brake.
3) power seat doesnt work
4) hazard light doent work.
Does someone know if the parking shift lock has anything to do with this? And where is the switch located?
All the fuses are hot, and everything else works fine in the car (I mean it starts, AC blows, etc)
Its really weird, I am clueless how this happened. My guess is something was moved inadvertently, but what?
Any help is greatly appreciated.
JC
cars, they are like women: cant live with 'em and cant live without 'em
96_4.6_MN12 is offline
post #2 of 6 (permalink) Old 07-31-2002, 02:45 AM
Question Double check you 15amp STOP/HAZ fuse
You say all your fuses are hot? Do you mean they have power or are they physicly hot? I would have another look at the 15amp STOP/HAZ fuse because it powers everything you describe except your power seat. Also go back and double check your wire install you have shorted something.
Chris............
Chris W is offline
post #3 of 6 (permalink) Old 08-01-2002, 04:49 PM
Sounds like you blew a fuse.
BigBird101 is offline
post #4 of 6 (permalink) Old 08-01-2002, 05:56 PM
MadDog2020's Avatar
Which fuse would that be? can you enlighten us?
1998 Toyota Supra
with fresh rebuilt T12b x2
MadDog2020 is offline
post #5 of 6 (permalink) Old 08-02-2002, 03:45 PM
Already said what it is!?
Read the title of my last post it says and its content.
" Double check you 15amp STOP/HAZ fuse "
Thats what its called and it explains what it powers.
Chris W is offline
post #6 of 6 (permalink) Old 08-16-2003, 01:05 AM
96fordtbird's Avatar
Send a message via AIM to 96fordtbird Send a message via Yahoo to 96fordtbird
have you fixed this part yet?
96fordtbird is offline
