Help! - TCCoA Forums
post #1 of 5 (permalink) Old 11-19-2007, 09:48 PM Thread Starter
PDL2MDL
krazy4's Avatar
Help!
Alright I was driving the bird, and the oil pressure gauge started to kind of freak.
When I give it a decent amount of throttle the gauge goes to low, and when I get back up to cruise speed the gauge goes back to normal.
What is the problem?
I think it could be the sending unit but i don't know.
Please help guys.
Thanks.
http://www.youtube.com/watch?v=oMjdto07tuk
LX w/ true duals, cutouts
cone filter
Bird is gone replaced by an LS1.
krazy4 is offline
post #2 of 5 (permalink) Old 11-19-2007, 10:51 PM
ipsd1's Avatar
Have you checked the oil. Kinda sounds like it if low enough that when you rev it up. It sucks the oil up faster than it can return to the pan. Happens if you are really low.
Flyin with the bird's or runnin with the cat's either is better than ridin horses!
84 Turbo Coupe 2.3T, 88 intercooler/intake setup, T3-4 hyrbrid .60 trim, PC1 ECU, 35lbs/hr injectors, runnin 15psi
94 cougar xr7 inprocess of getting body fixed gonna be the new daliy, Then the turbo coupe get piant & body
ipsd1 is offline
post #3 of 5 (permalink) Old 11-19-2007, 11:27 PM
The Great Obucina's Avatar
its the sender or the contact.....your oil is fine. If you really had an oiling problem bad enough, you would know it in about 10 seconds....the pressure gauge goes to normal if the sender reads 7psi, its just a mo-ron gauge.
"Booyah". Stu Scott.
The Great Obucina is offline
post #4 of 5 (permalink) Old 11-21-2007, 12:07 PM
Trumpeter Extraordinaire
IronChopz's Avatar
A low oil level will cause the gauge to fluctuate as described, based on my experience. However, the sender/contact advice is good -- every oil change, I clean the contacts, and make sure the connection is tight. A loose contact will make the gauge reading fluctuate. If the sender is old, it would not hurt anything to replace it.
IronChopz is offline
post #5 of 5 (permalink) Old 11-21-2007, 10:48 PM Thread Starter
PDL2MDL
krazy4's Avatar
Alright thanks guys.
The oil level is fine I checked it.
I guess the sender is just jacked.
It could definately be worse though
cone filter
krazy4 is offline
