Cams for the 4.6 - TCCoA Forums
post #1 of 13 (permalink) Old 11-23-2007, 12:05 PM Thread Starter
Blade Runner's Avatar
Cams for the 4.6
I was recently down at Bumbera's (those of you in Houston should know the place) and was asking them some questions about putting a set of cams in my 'Bird. The guy I was speaking with told me the car's computer would not like the new sticks, and I would have either too high or a really crappy idle, along with loss of a/c (????) and power brakes. I already tried the search, and I couldn't find what I was looking for. Any help?
Blade Runner is offline
post #2 of 13 (permalink) Old 11-23-2007, 12:23 PM
954.6tbird's Avatar
look at http://www.vtengines.com
i know a few guys who run VT Stage 1 and Stage 2 with sucess
they also sell comp cams and Crower
im looking into Crower Stage 1 myself
Ed
94 Thunderbird 4.6 PI
954.6tbird is offline
post #3 of 13 (permalink) Old 11-23-2007, 12:23 PM
Blade Runner,
Any time you make a change to your engine which drastically changes airflow (things like different intake manifold, hotter cams, larger MAF, etc), you'll need to have it tuned, but some of the other stuff is crap. I have Comp XE274H cams in my big bore, and yes, the idle speed needs to be higher and the idle is not as smooth, but my A/C and power brakes work just fine
MikeB
1997 Thunderbird Sport
5.0L-2V PI S/C
540 RWHP / 492 RWTQ
11.28 @ 123 MPH
MikeB is offline
post #4 of 13 (permalink) Old 11-23-2007, 12:28 PM
The Great Obucina's Avatar
how bout no.....http://www.modularfords.com/forums/s...ad.php?t=96049
Go with Mike Tymensky at Modularperformance.com
"Booyah". Stu Scott.
The Great Obucina is offline
post #5 of 13 (permalink) Old 11-23-2007, 12:29 PM
A crower2 along with a god tune will allow you to have everything you want. The guy you talked to should not be given any money to work on your car.
post #6 of 13 (permalink) Old 11-23-2007, 12:32 PM
954.6tbird's Avatar
so crower 2 is a good choice? should i have any PTV clearance problems on stock 95 pistons?
Ed
post #7 of 13 (permalink) Old 11-23-2007, 12:34 PM
954.6tbird's Avatar
ohhh i see, i didnt know about all that
sorry about that post
Ed
post #8 of 13 (permalink) Old 11-29-2007, 12:48 PM
Send a message via AIM to Trick Bird
Im running the Crower stage 2 cams no problems really. Idle suck and when you turn on the accesories it drops. Didnt get it turned for the cams yet either.
95' lx 4.6
true dual exhaust, mass air, 9 in k&n, 3:73 posi, 9mm ford racing wires, screamin demon coils, solid rubber trans mount, cobra r hood, clear corners, chrome bullit replicas.
Trick Bird is offline
post #9 of 13 (permalink) Old 11-29-2007, 12:57 PM
Bumbera's, along with most of the shops in Houston are crap.
post #10 of 13 (permalink) Old 11-29-2007, 01:45 PM
twin turbo 281's Avatar
I've been running comps npi stage 2s for years now with out tune. Performance would however be a lot better with a tune.
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #11 of 13 (permalink) Old 12-10-2007, 11:44 AM
MaleWhore
smokymance's Avatar
what u guys doing with the springs?
smokymance is offline
post #12 of 13 (permalink) Old 12-10-2007, 04:53 PM
Moderator & Teksid Whore
guitar maestro's Avatar
954.6tbird, you need springs if you're gonna do cams on a pre-96 head......i regret not doing springs when i had the heads off the car......a good set of springs is always a good idea even on a mild N/A motor with cams that will see higher RPMs than the stock computer allows
you'd have to keep the valve lift at or below 0.500" with pre-96 F4 heads.....even if you upgrade springs, there isnt enough clearance for more lift than that, so you could go with a Comp low-lift set, or have Crower custom grind you a set for lower lift
i honestly dont know how Trick_Bird is running those Crower Stage 2's on his 95 heads, so we'll just have to ask him
guitar maestro is offline
post #13 of 13 (permalink) Old 12-11-2007, 05:29 AM
I've been running the comp low lift stage 2s for 3 years now (about 50K on them) with no issues on a completely stock 95 motor. Ive had great luck with the stock ecu working with them some people don't have good luck getting the setup to run right. I've got by with tricking the computer but soon I'll be able to tune the setup. It lopes pretty good and I have been running stock converter, 3.08s and so on up until now.
