Does this sound like a bad computer??? - TCCoA Forums
post #1 of 4 (permalink) Old 11-24-2007, 10:30 AM Thread Starter
RodKnockin5.0's Avatar
To start off its a 94 Cougar that is puffing white smoke that smells like pure gas and even started dripping out the mufflers. I figured it would be a fuel injector stuck open so to try to narrow it down to which one I started to pull off fuel injector wire harnesses to see which one would make a difference. What I found was three injector didnt make a difference. It was cyl. 2, 6, 7. They are on seperate coil pack. I cant remember which was which but I think 2 and 7 was on the same coil pack.
So I figured that 3 fuel injectors wouldnt go bad all at the same time so instead of buying 3 new fuel injectors I thought I would buy a computer from the junkyard and see where the that got me. the catch code is E4A3, is there any computer I could use or does it have to be the same one? While at the junkyard I figure I might pick up 3 injectors too just incase.
RodKnockin5.0 is offline
post #2 of 4 (permalink) Old 11-24-2007, 10:54 AM
The 94 and 95 puters were famous for this.
Bob
thunderferret is offline
post #3 of 4 (permalink) Old 11-24-2007, 06:45 PM
02 Explorer Pioneer
timb's Avatar
yep. new EEC should fix that issue
Birdless
timb is offline
post #4 of 4 (permalink) Old 11-24-2007, 10:42 PM Thread Starter
Well thanks.! Turns out that was excactly what it was. This turned into the most worthless thread ever... Sorry!LOL
