Car Farted - TCCoA Forums
post #1 of 3 (permalink) Old 11-26-2007, 08:17 PM Thread Starter
TBirdsRMachismo's Avatar
Send a message via AIM to TBirdsRMachismo
Car Farted
So I'm pushing 170k on the odometer. Every oil change I notice I burn roughly a quart of oil. Also when I stop on the mother I smell a touch of oil burned with a tiny bit of smoke. It's very subtle, but my question is, isn't this normal to happen eventually on these engines?
96' 4.6l LX Sport - Modding put on hold for awhile
91' Chevy 1500 - Can't wait for the 383 Stroker
TBirdsRMachismo is offline
post #2 of 3 (permalink) Old 11-26-2007, 08:40 PM
Perfectly, Absolutely, Positivity, without a doubt Normal.
I'm sitting at 192,000 - really more than that since my odometer wasn't working for about a year before I replaced the odo. gears - and mine burns oil too. I don't smell it like you mentioned though. Yours must be leaking oil onto the manifold from a valve cover gasket or something and it's being burned off.
There's also the valve seals that don't do their job like they should at 100K+ miles. Knowing that this happens, just keep an eye on the oil and don't let it get low. Add a quart or so between oil changes and you'll be fine.
post #3 of 3 (permalink) Old 11-26-2007, 10:56 PM Thread Starter
Alrighty, sounds good
