Iac - TCCoA Forums
post #1 of 5 (permalink) Old 11-30-2007, 07:21 PM Thread Starter
T-BIRD 90's Avatar
Iac
where is the IAC valve?
T-BIRD 90 is offline
post #2 of 5 (permalink) Old 11-30-2007, 08:13 PM
carlosthekat's Avatar
Driver side near the throttle body plenum. Here's a link with a pic of the iac valve.
http://info.rockauto.com/Motorcraft/...tml?CX1660.jpg
carlosthekat is offline
post #3 of 5 (permalink) Old 11-30-2007, 08:26 PM
94fastbird's Avatar
Send a message via MSN to 94fastbird
on ur 94 it's under neath the upper intake elbow very back of intake, oppisite side of egr
Current Mods:
balanced & blueprinted block. by my dad & I @ (The Engine Shop INC.) i'm running manley forged i beam rods, forged manely .020 16cc dish pistons, forged 8 bolt crankshaft thats been polished, corba high volume oil pump, block has been align bored & decked. ported and polished early production heads, heads have been milled, 3 angle valve grind, ported exhaust manifolds, gasket matched intake, dual inlet dual outlet dynomax turbo muffler underseat with 3inch turndowns. transmission heavy duty clutches, b&m shift kit, frrp t lock with 373.
Future Mods:
pi swap with some comp cams and the new trickflow intake, high stall torque converter and mark 8 drive shaft, kooks 3/4 lenth headers and xcal2
94fastbird is offline
post #4 of 5 (permalink) Old 11-30-2007, 08:40 PM Thread Starter
T-BIRD 90's Avatar
thanks
post #5 of 5 (permalink) Old 12-01-2007, 12:56 PM Thread Starter
T-BIRD 90's Avatar
the ding bat that owned it before i did unplugged the iac cord thing,and i pluged it back in.after i crank it up it goes to about 1200 rpms and then settles at about 850-900
