Problem removing battery??? - TCCoA Forums
post #1 of 2 (permalink) Old 12-09-2007, 03:46 PM Thread Starter
the bolt on the negative cable is completely stripped...it is round. I can't get it to budge. Anyone have any ideas to remove it?? Normally I would try to dremel a slit on it and use a screwdriver, but im not sure if that is the smartest idea to create all those sparks over the battery. Cables and terminals are full of corrosion.
I guess plan b is to just remove the entire negative cable. Thanks for any help
bearswin34 is offline
post #2 of 2 (permalink) Old 12-09-2007, 03:56 PM
if your replacing the battery anyway I would just cut the terminal off and strip the wires and put them on a pinch clamp type, I like those better than the wrap around pinch type.
