3rd Set Of Plug Wires??? - TCCoA Forums
post #1 of 12 (permalink) Old 12-13-2007, 09:52 PM Thread Starter
scottyfireman's Avatar
I am on my 3rd set of wires in 5 months..... Bosh wires from AutoZone..... Has anyone had this problems??
But of course if they are lifetime i will just keep taking them back...
1997 LX 4.6 Stock--Future upgrades-- Flowmasters, 70mm TB, PI Head Swap
1997 Explorer 5.0--Future upgrades-- 31x10.5, 3" lift
1988 Mustang GT--Future upgrades--Tremec, Larger Cam, Better upper and lower intake
1996 LX 4.6 Stock--Flowmasters---Just bought it needs motor replaced..
scottyfireman is offline
post #2 of 12 (permalink) Old 12-14-2007, 03:01 AM
sCrEaMiN BiRd's Avatar
Hmm. The ford OEM's are good. I use the MSD's currently and so far no problems. The MSD's are supposed to increase the spark and thus increase horsepower, but i really couldn't tell the difference. I mostly got them because they look a little more visually pleasing...
sCrEaMiN BiRd is offline
post #3 of 12 (permalink) Old 12-14-2007, 03:59 AM
Gcline's Avatar
I have autolites from advance and I have had no problems (had to replace them once cause my intake was leaking and ruined the wires, not the wires fault though) What I did was wrap them in wire coils. Protects them better. I did have advance brands on for a while but it seems that normal engine heat broke them down, not strong at all. Id try first to put wire coils over them, and make sure the bare wires arent touching the alternator. Use wire spacers so they dont touch.
Daily Driver, 38mpg!
Gcline is offline
post #4 of 12 (permalink) Old 12-14-2007, 07:01 AM Thread Starter
Wire coils???? What exactily are you refering to?? The seprators are still there...
post #5 of 12 (permalink) Old 12-14-2007, 08:56 AM
Gcline's Avatar
Wire covers, i dunno I cant think of the name right now, I havent slept for 2 days because of work. Heres a pic of what im talking about, taken when i switched over to the PI intake.
Gcline is offline
post #6 of 12 (permalink) Old 12-14-2007, 11:35 AM
I think those would be wire looms.
post #7 of 12 (permalink) Old 12-14-2007, 10:41 PM
Hydafl's Avatar
Send a message via Yahoo to Hydafl
got a set from ford motorsport 10 mm work great not alot of dough.
Hydafl is offline
post #8 of 12 (permalink) Old 12-15-2007, 03:42 PM
I had the same problem with their duracrap wires
post #9 of 12 (permalink) Old 12-17-2007, 07:22 AM Thread Starter
Whats the problem?? Do they just break down that fast??
post #10 of 12 (permalink) Old 12-17-2007, 07:42 AM
jk69cat's Avatar
on a 4.6 use motorsport or stk ford only
mn12 less!
jk69cat is offline
post #11 of 12 (permalink) Old 12-18-2007, 02:31 PM
Carbon core verses stainless core.
Original plug wires, as well as low priced aftermarket wires ,are usually just a thin carbon-aramid fiber core. They work good as long as they are not near heat, which makes them brittle, which allows several actual breaks within the silicone core,which you cannot see, which permit various missfires to occure.
The stainless coil-wrapped around a carbon core work the best (MSD,etc), and they usually have better silicone insulation,which makes them less sensitive to heat,which allows for a near forever life,which makes the higher price actually cheaper in the long run.
edman is offline
post #12 of 12 (permalink) Old 12-18-2007, 06:59 PM
Paddycake's Avatar
I'll stand by that I have a set of MSD's on my 95 that have been on the car since 97 still going strong no issues. Paid like 80 bucks at Advance get a set for the 96-98 Mustang GT.
No matter how good she looks. No matter how cool she is about your "stuff". No matter how great she is in bed, someone somewhere is sick of her crap.
1995 850R with 18T, 3" downpipe, R.I.P. kit, ported intake,42lb injectors, N/A cams, 960 throttlebody, Rica tune(15psi in first and second 17psi in third and fourth). Bilsteins all around, V70R caliper and rotor upgrade, total lack of traction. IPD STB, Ultra Racing lower braces and RSTB.
Paddycake is offline
