A Few Problems With The Bird - TCCoA Forums
post #1 of 3 (permalink) Old 12-15-2007, 07:40 PM Thread Starter
94trouble's Avatar
Send a message via AIM to 94trouble
well the car has sat for about 2 months. I finally got it back on the road tonight, but with a few problems.
1.about 5 miles into driving, the CEL came on, and the oil gauge read above normal, it was right on the M of normal, where should i look?
2. the car is making a humming noise on the passenger side, it sounds to be right by the fuel filter but its hard to guess where its at
3. how do i check to see if the tensioner pulley, or idler pulley is going bad because one of the two is whining? and how much would it cost for the new part.
94trouble is offline
post #2 of 3 (permalink) Old 12-15-2007, 11:40 PM
1.) The oil gauge is a switch, and a 20? ohm resistor. It will always read pretty much the same, if you have over 7 psi of oil pressure.
2.) The last humming noise I had under the hood was the IAC; sounded like a pipe organ at times.
3.) Both pulleys are the same part at zone; they're about $20 each. The idler takes the most time, about a hour for both.
post #3 of 3 (permalink) Old 12-16-2007, 02:01 AM Thread Starter
94trouble's Avatar
does anyone have a pic, or can tell me where the IAC is so i can clean it?
tomarrow im gonna take it to schucks so they can scan codes for the check engine light
