DOHC cam specs? - TCCoA Forums
post #1 of 5 (permalink) Old 12-17-2007, 02:04 PM Thread Starter
DOHC cam specs?
Does anyone have access to ford factory camshaft specs for 4V mustang cobras?
Im rebuilding a Mark VIII engine that I plan to keep naturally asperated for awhile. Im trying to find the best camshafts for some low-end torque. Comp cams has a good set but I can buy a set of 4V replacement cams from ford for half the price. I heard Aviator cams make good low end torque but, will they work for my engine?
Can anyone help me out?
StrmChkn4.6 is offline
post #2 of 5 (permalink) Old 12-17-2007, 09:24 PM
Refrigerator Raider Hater
GreenBird's Avatar
http://crower.com/cat/domestic/ford/...amshafts.shtml
top line of the last chart has a spec, but I think those are for "C" heads.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #3 of 5 (permalink) Old 12-18-2007, 04:42 AM
twin turbo 281's Avatar
I believe the marks cams are designed for lower end torque than the cobras higher revving cams. The navigators cams would work possible if you went to a C head??? The navi heads are different than the C heads due to their larger ports.
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #4 of 5 (permalink) Old 12-18-2007, 07:04 PM Thread Starter
Originally Posted by racecougar View Post
You can run "C" head cams in the "B" heads. I'm running a set of Ford GT cams in mine, and I'm very happy with them thus far.
The Mercury Marauder borrowed a few cams from the Aviator SUV to make better low end torque and both are Naturally aspirated. The 03 Cobra cams were built with a supercharger in mind
Im sure crower and comp make the perfect cam for what I want but Marauder cams are half the price and offer more bang for the buck. If I get Marauder cams, springs, and retainers I can cut my costs drasticly.
post #5 of 5 (permalink) Old 03-23-2008, 09:22 PM Thread Starter
To answer my own question and to help anyone else out who might have this question I found this on Modular Fords:
96-98 Cam Specs:
Intake: Primary Lobe 196 duration (at .050)/ 390 lift
Secondary Lobe 206 duration (at .050)/ 390 lift
Exhaust: 196 duration / 390 lift (at .050)
99/01 Cam Specs:
Intake: 194 duration (at .050) / 392 lift
Exhaust: 194 duration (at .050)/ 390 lift
Mach 1, 03/04 Cobra, Aviator, Marauder.
Intake: 184 deg @ .050"/0.394" lift
Exhaust: 196 deg @ .050 / .394" lift
I've been told Mark VIII cams are similar to the Aviator, Marauder, and Mach 1 cams.
