Loss of oil pressure on hard right turns?? - TCCoA Forums
post #1 of 7 (permalink) Old 12-20-2007, 01:17 PM Thread Starter
$.25 poster
AlpineBird's Avatar
Send a message via AIM to AlpineBird
Lately, whenever I pull a hard right, my oil pressure gauge drops to nothing and my check gauges light will come on. As soon as I come out of the turn it goes back to normal. I also noticed this happening when I make hard stops. The car runs fine otherwise, even when the gauge falls.
The car has leaky valve seals and this only used to happen when it was low on oil, now it happens all the time.
Is this an issue I should look into, or could it just be a faulty gauge/wire?
'96 Alpine Bird 281ci
- Clear Corners
- DynoMax Cat-Back
- Purchased with 36,000 miles, now at 101k
- No mods planned untill it's DD life is over
1998 5.9 Limited Grand Cherokee
- Flowmaster Exhaust
- AEM Brute Force Intake
- Mopar Performance ECU
- 275hp-395ft/lbs at the crank (est.) Track results in the spring!!!
AlpineBird is offline
post #2 of 7 (permalink) Old 12-20-2007, 01:37 PM
sounds like a fried sending unit to me, if the oil is on the level
post #3 of 7 (permalink) Old 12-20-2007, 02:19 PM Thread Starter
$.25 poster
AlpineBird's Avatar
I was thinking that also....is that alot of work to change out?
- Clear Corners
- DynoMax Cat-Back
post #4 of 7 (permalink) Old 12-20-2007, 02:23 PM
not really, remove a wire and unbolt it, teflon tape the new one, screw it on, attach the wire, I forget the price of the unit but its availble at almost any checker, autozone, pepboys, and the like..
post #5 of 7 (permalink) Old 12-20-2007, 03:19 PM
MattsLE97's Avatar
Send a message via AIM to MattsLE97 Send a message via Yahoo to MattsLE97
ya just check the oil make sure its at a good level. Basically the oil pressure guage on here is pretty much a dummy light. I did this to my 94 and worked much better and gave me accurate readings
http://forums.tccoa.com/showthread.php?t=75977
2000 dodge dakota 4.7L 4x4
Flowmaster 3" SI/DO 2.5
31" cooper stt tires (mud and off roading here I come)
MattsLE97 is offline
post #6 of 7 (permalink) Old 12-20-2007, 04:26 PM
RidinOnAir's Avatar
yeah, i second that the oil is probably low. Mine does that when it gets low. (hopefully this oil adapter gasket will solve the oil leak--which makes the light come on)
RidinOnAir is offline
post #7 of 7 (permalink) Old 12-20-2007, 11:36 PM Thread Starter
$.25 poster
AlpineBird's Avatar
nope not low this time....like i said before, it only used to do it when the oil was low, now it just does it all the time.
- Clear Corners
- DynoMax Cat-Back
