95 Mark VIII won't start - TCCoA Forums
post #1 of 19 (permalink) Old 01-03-2008, 02:04 PM Thread Starter
frankjc's Avatar
Send a message via Yahoo to frankjc
My $#@ car wouldn't start this morning. It cranks over fine, just won't start. No SES light, ran perfect last night. I kinda suspect the IAC, because a few times when it was cold, t had a low idle when first started. Also, it was below zero last night, and about 4 degrees when I tried to start it.
Any suggestions?
Drive it like you stole it!
frankjc is offline
post #2 of 19 (permalink) Old 01-03-2008, 02:12 PM
351cat's Avatar
Send a message via AIM to 351cat
if you suspect the IAC, you might tap on it while someone else cranks it. Or just take it off and clean it. Can you hear your fuel pump prime when you turn the key on? Thats another possibility...
Originally Posted by Mitch Hedberg
"Escalator Temporarily Stairs. Sorry For The Convenience."
Originally Posted by cougar_guy04 View Post
Red Green, is that you? Might consider looking into fabbing an intake setup that isn't so, well, ghetto.
351cat is offline
post #3 of 19 (permalink) Old 01-03-2008, 02:27 PM Thread Starter
frankjc's Avatar
I hear a noise in the trunk area when I turn the key. The car is at home, I am at work. I though that might be the fuel pump.
I gave up real easy this morning....tried for a few minutes to start it, got in the Explorer and went to work. I was too cold/frustrated/tired.
frankjc is offline
post #4 of 19 (permalink) Old 01-03-2008, 06:59 PM Thread Starter
frankjc's Avatar
I tried to pull codes with a jumper wire, froze my ass off, it's a whopping 6 degrees out there... came up with nothing that made any sense, obviously I wrote the codes down wrong. I wrote:
111=pass
663=can't find this one
611=or this one.
I do hear the fuel pump prime.
It's too frigging cold to do anything else tonight.
frankjc is offline
post #5 of 19 (permalink) Old 01-03-2008, 07:22 PM
strung's Avatar
if you can hear your fuel pump priming then its working.....how well is a diff story.....id manually move the butterfly on your tb with the throttle cable linkage......just to make sure its not stuck.....as i always say, air/fuel/spark....always look for the main symptoms first.
pimp'n aint easy
mods: air silencer delete w/ k&n panel filter, magnaflow di/do tru duals w/all cats removed, sct 92 oct tune by blue oval chips, tokico advanced handling suspension kit
strung is offline
post #6 of 19 (permalink) Old 01-03-2008, 07:35 PM
if the wiring harness is the same as a birds,the wires that go to the crank sensor sometimes act up.it happened to mine a couple of times.try reaching down by the A/C compressor and moving the wires.
shelbyseven is offline
post #7 of 19 (permalink) Old 01-03-2008, 09:09 PM Thread Starter
frankjc's Avatar
Thanks for the ideas. I will try them once it warms up a bit.
frankjc is offline
post #8 of 19 (permalink) Old 01-03-2008, 10:05 PM
dDUBb's Avatar
We had a problem on a 95 Mark not long ago .. wouldnt start on cold mornings, then it just wouldnt start at all. The crankshaft position sensor was replaced and it has been fine ever since.
dDUBb is online now
post #9 of 19 (permalink) Old 01-04-2008, 07:17 AM Thread Starter
frankjc's Avatar
How could I test the crank sensor?
frankjc is offline
post #10 of 19 (permalink) Old 01-04-2008, 08:27 AM
Amateur Expert
Embalmer's Avatar
Send a message via AIM to Embalmer
First, reach down to the left of the crank pulley and find the sensor. Then, grab the wiring going to it and push up and to the right while wiggling in order to get a better connection. Then, turn the key and watch the motor run!
Here's a pic of the sensor:
2007 Ford Mustang GT Premium - SOLD March 2014.
2013 Ford Taurus SHO (TUXESHO) Tuxedo Black Bone stock for now.
Embalmer is offline
post #11 of 19 (permalink) Old 01-04-2008, 09:11 AM Thread Starter
frankjc's Avatar
I would love it if it turns out to be that simple! If it ever warms up here, I will try it. Supposed to be a whopping 31 degrees here today! They are saying 60 next week......
Too bad this couldn't happen last week when I was on vacation!
frankjc is offline
post #12 of 19 (permalink) Old 01-04-2008, 09:18 AM
Have you tried starting it while giving it a little gas (opening up the throttle plate a little)? That helps if it is the IAC.
Bangster is offline
post #13 of 19 (permalink) Old 01-04-2008, 09:35 AM Thread Starter
frankjc's Avatar
Haven't tried that yet, but I will...it's been too cold.
frankjc is offline
post #14 of 19 (permalink) Old 01-04-2008, 05:41 PM Thread Starter
frankjc's Avatar
It runs, now I see coolant.......
Ok, I got it running. Before I tried it, I crawled under the car and pushed and pulled on the CPS connector. I got in the car and turned the key. It did not start right away, but when it did, it idled a little slow for a few minutes, then ran as normal. I am not sure what made it start, if it was from wiggling the connector, or if it was because it was a little warmer out today (30's). We'll see what happens tomorrow morning.
While I was under there, I noticed some coolant on the sway bay, directly in front of the crank pulley. Not sure where it is coming from, but pretty sure it's not the water pump. Anything common that leaks in that area?
I guess tomorrow after work, I will put it on the lift and check that out. Maybe I'll pull the CPS connector off and clean it out, just because.
Thanks.
frankjc is offline
post #15 of 19 (permalink) Old 01-04-2008, 07:52 PM
Amateur Expert
Embalmer's Avatar
Thanks.
Coolant could be leaking out of the radiator (hoses) or the water pump. There is a weep hole on the pump housing - check that for moisture. You can also pressurize the system and look for leaks.
I'd bet my paycheck this week it was the sensor harness. I've seen it dozens of times, and had it happen to me a few times before I eventually replaced the harness.
Embalmer is offline
post #16 of 19 (permalink) Old 01-04-2008, 08:28 PM Thread Starter
frankjc's Avatar
I looked under the pump with a mirror, it does look wet.
I'll probably change it this weekend. Probably do an IAC too.
frankjc is offline
post #17 of 19 (permalink) Old 01-05-2008, 10:06 PM Thread Starter
frankjc's Avatar
It's the radiator leaking......
frankjc is offline
post #18 of 19 (permalink) Old 01-05-2008, 10:14 PM
94mncougar's Avatar
Send a message via AIM to 94mncougar
radiator.com is a good site to get one.
Stephen
Winter mods included:
- Developing Rocker Rust
- Saggy Suspension - fixed!
- Chipped paint
- I'm sure more to come... TOTALED
94mncougar is offline
post #19 of 19 (permalink) Old 01-06-2008, 09:12 AM Thread Starter
frankjc's Avatar
Thanks, I'll check that site out.
It's looking like I will be changing the oil pan soon too.
frankjc is offline
