Sudden loss in MPGs - TCCoA Forums
post #1 of 13 (permalink) Old 01-06-2008, 12:38 AM Thread Starter
$.25 poster
AlpineBird's Avatar
Send a message via AIM to AlpineBird
Sudden loss in MPGs
My car has been doing pretty good on gas ever since I owned it but lately all of the sudden it has been averaging between 10-12 miles per gallon in the city. I used to get at least 16-17. It was a real sudden change.
What could have caused this so suddenly? I know the car needs new injectors but it has needed them for a couple years now. Also the MAF was replaced in the last two years and the air filter is pretty clean.
What should I check? Anyone else ever experience a sudden loss like this?
'96 Alpine Bird 281ci
- Clear Corners
- DynoMax Cat-Back
- Purchased with 36,000 miles, now at 101k
- No mods planned untill it's DD life is over
1998 5.9 Limited Grand Cherokee
- Flowmaster Exhaust
- AEM Brute Force Intake
- Mopar Performance ECU
- 275hp-395ft/lbs at the crank (est.) Track results in the spring!!!
AlpineBird is offline
post #2 of 13 (permalink) Old 01-06-2008, 01:09 AM
TGJ
Baddest N/A NPI in Canada
TGJ's Avatar
I have seen this happen often. Any big change in weather recently, did it just get colder outside? Right now my 5.0L 4x4 is getting 12 MPG in the city 18 MPG on the highway with the temperature +2 to -10 Celsius. When it gets to -20 outside, the mileage drops to around 7 MPG city and 12 MPG highway. That could explain it...
TGJ is offline
post #3 of 13 (permalink) Old 01-06-2008, 01:22 AM Thread Starter
$.25 poster
AlpineBird's Avatar
Yeah, actually the temps have dropped dramatically this week. I thought about this being the reason, but I've had this car through 3 pretty cold winters and I have never seen this happen before....
- Clear Corners
- DynoMax Cat-Back
post #4 of 13 (permalink) Old 01-06-2008, 11:43 AM
There's more air in the colder air, for one.
The other thing is the amount of ethanol they put in gas when it's cold; ethanol=bad mileage.
My winter gas dropped me about 6 mpg this year; that seems to be what you are seeing...
O2 sensors made the most difference in my mileage; old sensors suck.
post #5 of 13 (permalink) Old 01-06-2008, 01:57 PM
Who is John Galt?
Same here. Didn't hit me as hard on the highway but in town . . . holy crap.
Between the cold air and winter fuel blend, my mileage (even with the 3/4 of an engine) tanks.
"Won't work, can't be done"
cougar_guy04 is offline
post #6 of 13 (permalink) Old 01-06-2008, 05:15 PM
Makes me wonder about the advantages of "oxygenated" gas. It's supposed to cause less pollution but then ....we burn more of it to go the same distance!!!
Bob
thunderferret is offline
post #7 of 13 (permalink) Old 01-06-2008, 05:25 PM
The energy per mile is lower on the highway, so the loss is less noticeable; in the city, every bit counts.
The biggest part of converting to E85 will be the huge gas tanks...or a daily fillup.
post #8 of 13 (permalink) Old 01-06-2008, 06:19 PM
Cavy's Avatar
which 02 sensors would be the most beneficial to fuel mileage...upstream or downstream?
Cavy is offline
post #9 of 13 (permalink) Old 01-06-2008, 07:47 PM
The upstream sensors are the only ones that control the engine...
The others apparently only tell you that your cats are bad.
If the rear ones go really bad, they will bring down the whole system, tho.
"Sensor circuit error" or something like that...I don't remember the code.
I bought two new ones, and got ~+5mpg (22 to 28) last summer; you won't see that much on winter gas unless they're really bad...
Mine originally started throwing codes, and I replaced the front ones (fixed almost all the codes), and moved one of the old front ones to the rear position that was giving me issues, and no more hassle.
The gas mileage was a nice bonus!
You can turn off the rears with a tune.
post #10 of 13 (permalink) Old 01-06-2008, 09:22 PM
sounds like typical 10% ethanal mix to me. try to find somewhere with regular gas.
post #11 of 13 (permalink) Old 01-07-2008, 12:12 AM Thread Starter
$.25 poster
AlpineBird's Avatar
thanks guys, i am seeing that this is more then likely the problem. The temps reached about 50 F today and the mileage seemed to have gone a up a little.
- Clear Corners
- DynoMax Cat-Back
post #12 of 13 (permalink) Old 01-07-2008, 11:35 AM
No going to find it on the East Coast. Sucks.
Bob
post #13 of 13 (permalink) Old 01-07-2008, 05:37 PM
Who is John Galt?
Bob
Same in the Midwest
