4.6 intake for pi swap - TCCoA Forums
post #1 of 10 (permalink) Old 01-08-2008, 12:42 AM Thread Starter
sloth92's Avatar
What is the best intake to use when doing a pi swap on a 95 4.6, I was looking at the typhoon intake because it looks awesome and is all shi................... oh sorry shiny objects distract me any way it looks cool but I was wondering about performance because I read a post about a typhoon intake for the 5.0 and it makes me worry. any info is much appreciated. also I dont give a crap about hood clearance I will be doing a cowl induction hood so I will cut the stock hood if needed and brace it to make it close.
Got the only bird with Lambo Doors in Texas!
Thanks Luke!
97 Thunderbird 4.6
1992 Merc. Cougar 5.0
1995 Merc. Cougar 4.6
sloth92 is offline
post #2 of 10 (permalink) Old 01-08-2008, 01:25 AM
just get a pi intake, the typhoon is junk
post #3 of 10 (permalink) Old 01-08-2008, 01:39 AM
The PI intake is much cheaper too.
post #4 of 10 (permalink) Old 01-08-2008, 01:58 AM
94fastbird's Avatar
Send a message via MSN to 94fastbird
if u got the money do the bullitt intake a trickflow, but like was said earlier cheapest bet 99-04 pi intake, u can pick one up for $130-$250.
Current Mods:
balanced & blueprinted block. by my dad & I @ (The Engine Shop INC.) i'm running manley forged i beam rods, forged manely .020 16cc dish pistons, forged 8 bolt crankshaft thats been polished, corba high volume oil pump, block has been align bored & decked. ported and polished early production heads, heads have been milled, 3 angle valve grind, ported exhaust manifolds, gasket matched intake, dual inlet dual outlet dynomax turbo muffler underseat with 3inch turndowns. transmission heavy duty clutches, b&m shift kit, frrp t lock with 373.
Future Mods:
pi swap with some comp cams and the new trickflow intake, high stall torque converter and mark 8 drive shaft, kooks 3/4 lenth headers and xcal2
94fastbird is offline
post #5 of 10 (permalink) Old 01-08-2008, 01:58 AM
Moderator & Teksid Whore
guitar maestro's Avatar
yea with stock PI cams and unworked PI heads, the PI intake is the best bet....with aftermarket cams and/or ported heads, an SVO or Bullitt intake manifold would be best, or perhaps the Trickflow piece
guitar maestro is offline
post #6 of 10 (permalink) Old 01-08-2008, 11:34 PM
bob9646's Avatar
ive heard a few things about heat sink in these dat burned aluminum intakes. aluminum is very well known for its abilty to transfer heat. seen some dyno head to head runs on them vs stock pi. cold they pull just about even. hot they loose you 5-8 hp. not worth the money and the power for the shineyness IMO. if you want you could get some krylon plastic bonding spray paint and have that same appearance. jk
Shipping out to basic training for the army on april 12th!
Bird is on serious down time
bob9646 is offline
post #7 of 10 (permalink) Old 01-08-2008, 11:55 PM
twin turbo 281's Avatar
but its always nice to have a plastic intake when a backfire ripps thru the intake
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #8 of 10 (permalink) Old 01-09-2008, 12:25 AM
running at identical inlet temps, at 6000 RPMs, my aluminum SVO intake was pullin in nearly 10% more air compared to the PI intake (28 #/min vs 30.55 #/min)......the SVO was not cooled down or anything, and the engine had been running at least 30 minutes with coolant temp within 2 or 3 degrees from the PI test......so i really dont know where you're getting a 5-8 HP loss.....all things equal and optimal, airflow is power...plain and simple
post #9 of 10 (permalink) Old 01-09-2008, 09:45 AM
bob9646's Avatar
it was about the typhoon, i read it on crownvic.net like almost a year ago, there were pictures of his car doing the individual pulls and everything. maybe he goofed on the swap and messed somthing up... not sure. not my personal experience
bob9646 is offline
post #10 of 10 (permalink) Old 01-09-2008, 09:52 AM
Dusty's Avatar
I have heard the same thing about Typhoon on the Mustang boards. There seems to be agreement low end power is not as good as a PI. Typhoon makes more power above 6500 rpms on a stock PI engine.
1995 PI Tbird
1998 TA Vert
2004 Buick Regal GS
2000 Honda ST1100
1990 Mazda RX-7 2+2
Dusty is offline
