Blower fan diagram - TCCoA Forums
post #1 of 3 (permalink) Old 01-13-2008, 12:52 AM Thread Starter
seawalkersee's Avatar
Blower fan diagram
Im loking for someone to help me out. I cant get my cd to read on either of my computers. I lost the blower fan for my heat. I need to get it fixed since it is sub 20s here when the sun goes down. I have power to the fan speed switch, but nothing comes out. I even went as far as to take the switch apart. I have no idea which wire is which setting or if there is a relay that goes between the switch and the thermal resistor. Can someone print the evtm set up for me please?
Its a 97 LX 4.6 with the manual switch.
Chris
Last edited by seawalkersee; 01-13-2008 at 12:53 AM. Reason: 'Cause I got to add stuff.
seawalkersee is offline
post #2 of 3 (permalink) Old 01-13-2008, 09:33 PM
Trumpeter Extraordinaire
IronChopz's Avatar
Hmmm...I do not think there was much, if any, difference between 1994 and 1997 systems. I can send the EVTM diagrams for the 1994 system (non-EATC), if you'd like. Send an email to [email protected]
IronChopz is offline
post #3 of 3 (permalink) Old 01-14-2008, 01:31 AM
Here's how the wiring is set up. There is nothing between the blower motor resistor and the switch.
