Mark Radiator - TCCoA Forums
post #1 of 23 (permalink) Old 01-24-2008, 12:36 PM Thread Starter
Jestkdn's Avatar
Send a message via AIM to Jestkdn Send a message via Yahoo to Jestkdn
Mark Radiator
Can I shoe horn a Mark VIII Rad into my 94 Tbird? I think the Mark is a 97. I found it on a junkyard run this weekend. Looked like a t-bone accident. Engine looks fine. Rad is there, not bent. Marks have bigger rads no?
I am as mechanically inclined as Hellen Keller is with a Rubik's Cube!
Jestkdn is offline
post #2 of 23 (permalink) Old 01-24-2008, 07:34 PM
It will bolt right in...it's the same radiator that your car came with stock.
-Rod
post #3 of 23 (permalink) Old 01-24-2008, 07:51 PM Thread Starter
Jestkdn's Avatar
-Rod
Damn, oh well. Was hoping it would help her run cooler. Thanks any way.
Jestkdn is offline
post #4 of 23 (permalink) Old 01-24-2008, 11:48 PM
justin case's Avatar
03-04 cobra radiators fit in with minimal mods,ive got one in my car and picked it up for around 100 bucks.
-Doug
95 T-bird, purple python,i'll drive it again.........someday.
http://www.facebook.com/home.php#/pr...73&ref=profile
justin case is offline
post #5 of 23 (permalink) Old 01-25-2008, 03:29 AM
the mark VIII fan is an upgrade for our cars
post #6 of 23 (permalink) Old 01-25-2008, 06:06 AM
True. I have one in my XR7, too. You may have a hard time finding one in a junkyard though.
-Rod
post #7 of 23 (permalink) Old 01-25-2008, 08:52 AM
joshbea6's Avatar
You can get them through the ford parts counter. Fubarian got one and the fan for around $170 IIRC.
joshbea6 is offline
post #8 of 23 (permalink) Old 01-26-2008, 12:01 AM
A 03-04 Cobra radiator and fan? When I ordered mine through Jason almost a year ago, it was $391.78 for the radiator, fan, and pigtail.
-Rod
post #9 of 23 (permalink) Old 01-26-2008, 05:21 AM
joshbea6's Avatar
like I said...IIRC (If I Remember Correctly)....and apparently I don't....(thanks Rod...)
joshbea6 is offline
post #10 of 23 (permalink) Old 01-26-2008, 12:57 PM
Sorry, if that came across the wrong way, Josh. I didn't mean for it to sound harsh or anything.
-Rod
post #11 of 23 (permalink) Old 01-26-2008, 01:58 PM
joshbea6's Avatar
No offense taken. Was supposed to be funny....
joshbea6 is offline
post #12 of 23 (permalink) Old 01-26-2008, 02:47 PM
Cool.
-Rod
post #13 of 23 (permalink) Old 01-26-2008, 10:18 PM
Battery's Avatar
Send a message via AIM to Battery
Anyone know what the cobra one ways vs the stocker?
"It's all in the reflexes"
LE RIP
Now 96 Mark VIII
Battery is offline
post #14 of 23 (permalink) Old 07-04-2008, 02:30 AM
Does the Mark 8 fan just plug into the stock wiring harness for the 94 4.6 fan??? I am assuming that that the shroud will fit the stock radiator.
Max
2014 Chevy SS
1995 T-Bird LX 4.6
1994 T-Bird LX 4.6
2014 Chevy SS Sedan
2013 Camaro SS
2009 Dodge Charger Daytona
1975 Oldsmobile Delta 88 Royale Convertible 455.
Smkn600ctd is offline
post #15 of 23 (permalink) Old 07-04-2008, 10:01 AM
Yes and yes.
-Rod
post #16 of 23 (permalink) Old 07-04-2008, 10:45 AM
Lil Mikey's Avatar
Not to jack your thread or anything, but I could really use the EGR tube of a 97 Mark. Right now I have a cap for the port on the header so I can run without it, but I would like have one installed so if I ever have to pass emissions it won't be too much hassle. The local bone yard never has them. Let me know the $$$ if it isn't too much trouble and you feel like making a couple bucks.
Mike
1995 Thunderbird SC Terminator 6spd http://forums.tccoa.com/showthread.php?t=89775
2006 F250 QuadCab Shortbox 4x4 6.0L- the I'm going to have to tow the T-Bird home when I break it vehicle.
1980 Dodge Mirada - Collecting tree sap at grandma's house - My first engine swap(s) - Slant 6 to 318 to 400
1973 Firebird Formula - Totaled - next in line after the T-Bird gets done. - Pontiac 350, 4spd, Ford 9", etc
Lil Mikey is offline
post #17 of 23 (permalink) Old 07-15-2008, 12:00 PM
Yes and yes.
-Rod
Does anything else need to be swapped or rewired for the mark fan to work in the 94 bird? Or is it as simple as plugging in the Tbird harness into the Mark8 fan?
Max
2014 Chevy SS
1995 T-Bird LX 4.6
1994 T-Bird LX 4.6
2014 Chevy SS Sedan
2013 Camaro SS
post #18 of 23 (permalink) Old 07-15-2008, 07:29 PM
Moderator & Teksid Whore
guitar maestro's Avatar
you will severely shorten the life of your alternator and battery because the mark VIII fan is a single speed, so the only wire that powers it is rigged up to the high-speed circuit.....and upon initial start-up, needs about 80A of current....such a current draw is not good...that is why the mark VIII pcm uses a PWM voltage signal to control the duty cycle of its fan
guitar maestro is offline
post #19 of 23 (permalink) Old 07-16-2008, 01:40 AM
I see what your mean.....when the fan kicks on the voltmeter drops but recovers right away. But it sure does cool things off in a hurry when it kicks on.
So what do I need to get from the Mark (there's only one at the pic-a-part, and its complete-engine and everything), to make it work correctly???
Max
2014 Chevy SS
1995 T-Bird LX 4.6
1994 T-Bird LX 4.6
2014 Chevy SS Sedan
2013 Camaro SS
post #20 of 23 (permalink) Old 07-29-2008, 08:31 PM
J.Miller's Avatar
Mike
You will need to get creative with that one... High temperature silicone hose and copper tubing will work.
Gotta keep things tight though.
So will copper tubing and more expensive high temperature Swagelok fittings...
J.Miller
East Coast Rolling Thunder!!!!
Official Eastern and Central PA chapter of the SCCoA!
J.Miller is offline
post #21 of 23 (permalink) Old 07-29-2008, 11:54 PM
There were several different cooling fans used in the Mark. I believe the earlier ones were 2-speed and higher flow than the TBird.
Mitch
MitchB is offline
post #22 of 23 (permalink) Old 07-30-2008, 05:20 AM
J.Miller's Avatar
None are single speed... The 93-96 spin 1,100 RPM on low speed and 1,850 RPM on high speed. The 97-98 spin 1,800 RPM on low and 2,225 RPM on high.
I just went with a big ole Griffin and a stock fan for starters. No need to change electronics.
J.Miller
J.Miller is offline
post #23 of 23 (permalink) Old 07-30-2008, 07:07 AM
But the Gen II's do use PWM to power the fan based on what the manual says (IIRC).
69 F100 LWB w/460 Engine
post #24 of 23 (permalink) Old 07-30-2008, 08:35 AM
02 Explorer Pioneer
timb's Avatar
I think you are missing the obvious here. If you are running too hot there is a problem and a bigger rad isn't the answer unless you old one is clogged.
Birdless
timb is offline
post #25 of 23 (permalink) Old 07-30-2008, 08:44 AM
ahah in the winter time my cobra radiator keeps my **** at 168-171.... And I have a 180 degree thermastat I replaced the 160 that was in there. damn thing was keeping the car at like 155 last winter before I changed it out. But yes... Cobra Fan cools things off pretty damn quickly.
FunktasticLucky is offline
