Hum from rear - TCCoA Forums
post #1 of 3 (permalink) Old 01-31-2008, 09:35 AM Thread Starter
Hum from rear
Hey guys quick question. Today I noticed that when my car is idle I am hearing a humming sound coming from the rear of the car. But one thing is that currently I am having some idle issues I guess due to the bad O2 sensor on it. When the car is idling normally around 650 RPMs I do not hear the sound. When I am idling the RPM's dip a bit to the 450-500 range and that is when I hear the hum. Could this be a sign of the fuel pump on its way out? The reason I am thinking that is the car was sitting for awhile with stagnant fuel in it and maybe thats what put it on its last legs. How long do you think I could push it if it is the fuel pump?
Peppers30 is offline
post #2 of 3 (permalink) Old 01-31-2008, 10:00 AM
Fuel Pump. might try changing the fuel filter a dirty one will put alot of load on it..
Justin McC
Stinkfist04 is offline
post #3 of 3 (permalink) Old 01-31-2008, 10:04 AM
oh yeah and "pushing it" wouldn't be a good idea especially if it's your dd. better to change it in the driveway then it leaving you stranded with a tow bill. plus it is or will lean your engine out. scary thought.
Justin McC
