Clicking from oil pan/trans bell (2v) - TCCoA Forums
post #1 of 12 (permalink) Old 02-05-2008, 04:19 PM Thread Starter
ry2lazy4u's Avatar
Send a message via AIM to ry2lazy4u
Exclamation Clicking from oil pan/trans bell (2v)
I have a 95 with approx 300,000mi. Its my daily driver and it just started ticking up to about 1500rpm under 50% accelleration. I dont have any check engine lights and the car still runs fine. No smoke either and it doesn't burn oil. But it ticks pretty loudly under load and i'm wondering if i should just park it or keep driving it until it pops. The trans front seal is leaking, the trans fluid level is ok (mercon sp inside). Im planning on a motor/trans swap and i do have money in the bank waiting for that, but im gonna get all the miles i can out of the stock engine/trans.
It is defenitly coming from below the car and not the heads. Any advice would be appreciated.
Thanks!
Three Birds are Better than 1! Current rides...
Red 96 LX 4.6 <----> Blue 95 LX 4.6 <----> Pearl 94 LX 4.6 (parts car!)
ry2lazy4u is offline
post #2 of 12 (permalink) Old 02-05-2008, 04:30 PM
sik97bird's Avatar
torque converter maybe getting ready to pop
or your getting ready to throw a rod bearing
any metal in the pan???
sik97bird is offline
post #3 of 12 (permalink) Old 02-05-2008, 05:29 PM
Hydafl's Avatar
Send a message via Yahoo to Hydafl
maybe a broken cat converter?
Hydafl is offline
post #4 of 12 (permalink) Old 02-05-2008, 05:32 PM Thread Starter
ry2lazy4u's Avatar
i will check the plug magnet when i change the oil next, it only has 1month on the current oil and im not gonna check the plug yet. the cat converters already have been silenced with large hose clamps and its not the cats. its coming from the crank it sounds like, or maybe the trans torque converter area. the trans is leaking and i wouldn't doubt that it is about to go.
post #5 of 12 (permalink) Old 02-05-2008, 06:14 PM
Does the ticking vary with engine RPM? It could just be an exhaust leak.
post #6 of 12 (permalink) Old 02-05-2008, 09:17 PM
frankjc's Avatar
Send a message via Yahoo to frankjc
egr tube?
Drive it like you stole it!
frankjc is offline
post #7 of 12 (permalink) Old 02-05-2008, 09:58 PM
MadGoat's Avatar
Send a message via AIM to MadGoat Send a message via MSN to MadGoat
i have the same problem, though mine is exactly that, an exhaust leak and a bad cat.
NIGEL, WHEN ARE WE GONNA DO THE EXHAUST MAN! -jk-
~MG~
MadGoat's Birds
94 Thunderbird LX 4.6L PI
03 Aluminum PI Engine, J-Mod, Aluminum one piece drive shaft, 3.27's, 2.5" to single 3" custom MagnaFlow exhaust, 07 17x8 Bullit Wheels
97 Thunderbird LX 4.6L V8
RIP
MadGoat is offline
post #8 of 12 (permalink) Old 02-06-2008, 09:40 PM Thread Starter
ry2lazy4u's Avatar
yup it needs trans rebuild, new t/c, and engine rebuild. my ford guy only works on deisels now but has a SC 94 badass too and he doesnt know much about the 4.6 birds off the top of his head. he thinks its the timing chain tensioner. is there a tensioner on the 4.6 timing chain(s)?
engine-
leaking oil pan/oil pres sens. (extreemly slow leak)
ticking! dam!
300,000mi approx (trans also)
trans-
shutters into 4th always unless you really baby it
leaks out of front
im just gonna take it in soon, hopefully i wont mess anything up too bad i have to go to school and work and this sucks. i may park it if the problem worsens, but it only ticks around 15-1700rpms and not that bad. so i think i can ride this out. im takin the birdy to ford tomorrow to have a 4.6 pro look this thing over and tell me what to do.
thanks for tips if y'all got any!
ryan
post #9 of 12 (permalink) Old 02-06-2008, 09:58 PM
There are 2 tensioners for the chains on the 4.6L, but if they were bad I would think the noise would happen all the time, not at a specific RPM range.
post #10 of 12 (permalink) Old 02-06-2008, 10:11 PM Thread Starter
ry2lazy4u's Avatar
thats what i thought too. maybe the drivers side tensioner is just getting slightly worn out? I listen to this motor and watch gauges like a hawk so if it sounds real bad ill turn it off pop the hood and call tripple A. i've beat the hell out of this car every day for the last 5 years. ill find out a lil more tomorrow. im gonna drive it tomorrow and hopefully not mess it up bad. but another motor will only cost me like $100 max so im not worried.(old used tbird 4.6 obviously)
post #11 of 12 (permalink) Old 02-06-2008, 10:24 PM
If you had a problem with oil pressure (like a worn out oil pump), watching the gauges won't do you much good. The oil pressure gauge doesn't tell you anything except that there is over 4.5 - 7.5 psi of oil pressure.
post #12 of 12 (permalink) Old 02-07-2008, 02:46 PM Thread Starter
ry2lazy4u's Avatar
bad crankshaft bearing is the diagnosis.
this is coming from the 4.6 guy at my local ford shop, who does side work for me.
I dont doubt it.
he said i should just buy a new 4.6 and be done. rebuilding it will take about 1-2 months and has no warranty. a new motor $2400 plus tax from ford has a 3yr/70,000mi warranty.
what he really suggests is that i buy a tbird used and just take the motor trans from it which is a good idea, b/c the junkyards are getting thin with tbirds these days.
