good deal. - TCCoA Forums
post #1 of 3 (permalink) Old 02-15-2008, 12:18 AM Thread Starter
94fastbird's Avatar
Send a message via MSN to 94fastbird
good deal.
finally i got a good deal on some pi heads. i asked my instructor at school, if they'd sell, these 5.4 heads that came off 99 econoline van, (demonstration motor). he just told me i could have them if i swap the heads off of it. he said i could put early production heads on it if i wanted to replace the others. so i think i'm going to go through with it . the only thing i have to do is drill out one valve cover bolt hole and use an easy out. cause one of the bolts broke in it. but before i definatly do get them, i'm going to pressure check them and make sure they dont leak. you guys think i should go through with this?
Current Mods:
balanced & blueprinted block. by my dad & I @ (The Engine Shop INC.) i'm running manley forged i beam rods, forged manely .020 16cc dish pistons, forged 8 bolt crankshaft thats been polished, corba high volume oil pump, block has been align bored & decked. ported and polished early production heads, heads have been milled, 3 angle valve grind, ported exhaust manifolds, gasket matched intake, dual inlet dual outlet dynomax turbo muffler underseat with 3inch turndowns. transmission heavy duty clutches, b&m shift kit, frrp t lock with 373.
Future Mods:
pi swap with some comp cams and the new trickflow intake, high stall torque converter and mark 8 drive shaft, kooks 3/4 lenth headers and xcal2
94fastbird is offline
post #2 of 3 (permalink) Old 02-15-2008, 06:34 PM
Moderator & Teksid Whore
guitar maestro's Avatar
do you have everything that is needed to convert a 94/95 style intake to a 96+ intake? have you searched on this?
if so, and if you can get the windsor valve covers for it, sure go for it...cheap bang for the buck....PI heads/cams/intake would get you about 200-220 RWHP untuned, and close to 240 RWHP tuned
guitar maestro is offline
post #3 of 3 (permalink) Old 02-15-2008, 09:35 PM Thread Starter
94fastbird's Avatar
yea i have, the 96 fuel rail, vaccum lines, tps, egr valve. gonna be getting intake still thinking about the new trickflow piece. gonna reuse my 94 front cover. and drill the holes out, just like it says in forum, if i need to. yea i'll be getting vavle covers for it.
Current Mods:
Future Mods:
