Aternator pulley question about underdrive pulleys - TCCoA Forums
post #1 of 14 (permalink) Old 07-31-2002, 10:52 AM Thread Starter
I am cancelling the order at CarParts.com because I would like to install the things before Xmas...anyway
I have a set of pullies coming but I think the ALternator pulley is a different size than it is supposed to be for our cars. I bought them fro ma guy with a GT but the part number for the GT and TBird is the same at the ASP website but the alternator pullies are not the same size. I forgot the sizes.
I have read a few places that the alternator pullies with the kits are the same size as stock so do I even need to worry about changing out the alternator pulley?
Now I want it to work right and get the most out of the set but if the stock pulley is the same as the underdrive alternator pulley then it doesn't matter.
what I need to know is if the underdrive sets alternator pullies are or are not the same?????
anyone know?
Mike
MZ-Bird is offline
post #2 of 14 (permalink) Old 07-31-2002, 11:03 AM
Automatic Weapon
Big-Al's Avatar
I got mine off a mustang and the alternator pulley was the exact same size, but it would not fit onto the alternator post, so I just left the stock alt. pulley on and everything went fine.
<----not throwing rocks at girls anymore
Big-Al is offline
post #3 of 14 (permalink) Old 07-31-2002, 11:10 AM Thread Starter
so i can just use th crank and water pump pulley?
thanks,
mike
MZ-Bird is offline
post #4 of 14 (permalink) Old 07-31-2002, 11:13 AM
Automatic Weapon
Big-Al's Avatar
Yep. Sure can, if you want to. I did not have a choice.
However, if the new one is smaller, put it on for that little bit of performance gain.....just because you want every bit of torque freed up that you can possible squeeze out of her!
Big-Al is offline
post #5 of 14 (permalink) Old 07-31-2002, 11:24 AM Thread Starter
thanks BIG AL!
Mike
MZ-Bird is offline
post #6 of 14 (permalink) Old 07-31-2002, 11:27 AM
Automatic Weapon
Big-Al's Avatar
Just let me know if you want that Bird to _really_ fly.......and your budget!
Big-Al is offline
post #7 of 14 (permalink) Old 07-31-2002, 10:37 PM
Back in Black
ShadowDragon's Avatar
Re: Aternator pulley question about underdrive pulleys
That sucks, I ordered mine from there on 7/19 and got them on 7/25
ShadowDragon is offline
post #8 of 14 (permalink) Old 07-31-2002, 10:40 PM
Sheepish
AverageJoe's Avatar
Send a message via AIM to AverageJoe Send a message via Yahoo to AverageJoe
I know you have to pay attention to your voltage meer when you have U/D pullies on, but what about when you leave the stock alternator pully on? Will it still charge fully sitting in drive at a stop light?
B Team - More skill, more results. A is only a starting point before progressing to B.
Member of the 'B-Team'. Finishing jobs the 'A-Team' can't handle.
AverageJoe is offline
post #9 of 14 (permalink) Old 07-31-2002, 10:44 PM
Back in Black
No it won't fully charge at idle, the cam pully is underdriving everything, with the alt pully and the waterpump pully you only make it do moreso on those.
post #10 of 14 (permalink) Old 08-01-2002, 03:40 AM
WaLieN's Avatar
Send a message via AIM to WaLieN
If you're really worried about getting stuck, trade in your current battery, and get a deep cycle one.
BTW, Big Al, about that pulley not fitting, was it a OE Mustang GT pulley, or an aftermarket one?
☼1997 Ford Thunderbird LX - 4.6L -K&N Panel Filter-Steeda U|D Pulleys-Steeda 180* Thermostat-Removed Intake Silencer-Polyurethane IRS Bushings-Tranny Cooler-Urethane Tranny Mount
☼1993 Mazda RX-7 Touring [VR] - Rotary Power rebuilt turbos & motor w/ 3mm Apex Seals - PWR Radiator - PFS Cat-Back - RB Intake Duct w/ K&N Panel - Manual Boost Controller - KG Differential Brace - Gotham Engine Torque Brace - Aluminum 45mm Front STB - B&M Short Throw Shifter - PFS Column Mounted Boost Gauge - Falken Azenis ST115s [235/40ZR17] on Speedy Mashie Silvers
WaLieN is offline
post #11 of 14 (permalink) Old 09-01-2002, 03:23 PM
ok, i know what the crank pulley does, but the other two are confusing me......can someone tell me if i got this right then......
alt pulley + Crank pulley = less hp than JUST the Crank pulley, but better recharge of battery?
and what's the water pump pulley for?
thanks!
93lx 3.8L
sanbei120 is offline
post #12 of 14 (permalink) Old 09-01-2002, 06:24 PM
Sheepish
AverageJoe's Avatar
Ok, you have three pullies.
Alt
Water Pump
Crank
The crank pulley is smaller, so it turns all of your accessories slower. The Water Pump and Alt pullies are bigger so they turn their respective accessories slower. Hence, everything is underdriven. You get best effect from using all three, but you can use any combination of stock and U/D pullies you want, but you might have to go to a different belt, I'm not too sure on that one.
When you U/D the Water pump, it pumps slower, and will cause the car to run a little warmer. When you U/D the alt, it isn't putting out as much juice, and doesn't charge the battery as well. Make sense now?
post #13 of 14 (permalink) Old 09-01-2002, 07:42 PM
Chapter Director Coordinator
jamesD's Avatar
for everyones knowledge
if anyone cares.. we checked steeda's u/d pulley with the stock alt pulley, and steeda's was barely smaller... that and the shop couldn't find the right socket to pull the pulley off, so we just left it...
JD
jamesD is offline
post #14 of 14 (permalink) Old 09-01-2002, 09:00 PM
great! thanks!
93lx 3.8L
