Temperature - TCCoA Forums
post #1 of 3 (permalink) Old 08-01-2002, 05:02 PM Thread Starter
Temperature
What's up with these cars. My temperature gauge is almost always on cool or just above. I know I don't need a new temperature gauge. My temp gauge has never even got to half way. Do these cars run cool all the time or is there something wrong?
BigBird101 is offline
post #2 of 3 (permalink) Old 08-01-2002, 06:00 PM
MadDog2020's Avatar
Re: Temperature
Though the gauge is not the most accurate in the world to me it sounds like you are running ok. I wouldnt worry about it at all.
1998 Toyota Supra
with fresh rebuilt T12b x2
MadDog2020 is offline
post #3 of 3 (permalink) Old 08-07-2002, 01:17 PM
Send a message via Yahoo to birdofprey
sender and sensor
I think that MadDog is right in that it's nothing to lose sleep over.
My guage uased to read straight up, then began a downward drift until one day it always read cool. So I replaced the temp sender (the one-terminal input; $11.50) and now I have much more confidence that the guage is accurate: it goes to about "M" at idle on hot days (I have u-pulleys, so the water pump isn't going as fast), but then coasts back down once I reach "usual" operating temperature.
Seeing that the sender was getting a false reading, I also replaced the sensor (the two-terminal device; $30) since this is the unit that delivers input to the EEC. I figured if one thing was crapping out, maybe the other one was as well.
birdofprey is offline
