Lmaf - TCCoA Forums
post #1 of 4 (permalink) Old 08-01-2002, 09:02 PM Thread Starter
Oc3digital's Avatar
Send a message via AIM to Oc3digital Send a message via Yahoo to Oc3digital
Lmaf
Will using LMAF require a new SUPERCHIP-or re-flash chip? I may have a bad MAF and can't see buying a stock MAF when I might be able to get by with a LMAF until I get a flash .
Oc3digital is offline
post #2 of 4 (permalink) Old 08-01-2002, 09:11 PM
Robinson's Avatar
Send a message via AIM to Robinson
yes. youre chip will have to be programmed for the new MAF.
www.innerlusion.com
89 SC 5 speed
FCoNE President
Robinson is offline
post #3 of 4 (permalink) Old 08-01-2002, 09:16 PM
MagerThom's Avatar
Talking If you're NA....
current theory is go with a Mustang GT MAF - you'll use
a larger percentage of the Tranfer Function and the
metered info should be a bit more accurate.
Nothing wrong with the LMAF, it's just programmed for a
wider range of air flow. You might be able to get a 'Stang
MAF on one of their sites from someone who's doing an
"upgrade".
You'll need a reflash or new chip depending what you have
currently. Contact Dennis Reinhart at:
http://www.reinhartautomotive.com/
Simply put - it's basically the only one used by members
of this board - with a few exceptions, of course.
Mager Thom
1997 AED Thunderbird LX
287RWHP 345RWTQ
"It's ALL about air flow...eveything else...is tuning..."
MagerThom is offline
post #4 of 4 (permalink) Old 08-01-2002, 09:20 PM Thread Starter
Oc3digital's Avatar
Thanks for the quick answer...Ill post tomorrow if I need 1. I expect to know from the shop by noon.
BTW I just found out my 95 cougar has the 96 motor.
