Sorry but more PI head questions - TCCoA Forums
post #1 of 2 (permalink) Old 08-05-2002, 07:19 PM Thread Starter
scott's Avatar
What is diff. between the FRPP PI heads (M-6049-D46} and the ones from a 99 mustang
(XL3Z-6049-GA] Thanks
97 LX sport 4.6
T-45 5 speed, 3.73 with track lock; PI heads, 02 MAF, #24 injectors,190 fuel pump,JBAs, 75mm TB. ect,ect.; Aluminium drive shaft. 13" PBR Brakes; Dennis chip, lowered with solid sway bar bushings and hiem joints; console mounted E brake WITH the cup holders; C&l Plenum, Steeda U/D; VERY big radiator; 2.5" duals, Magnaflows;B&M ripper shifter; bla..bla...bla...
Lincoln MKVIII 93.........sweet ride.
Bag-less, lowered.
scott is offline
post #2 of 2 (permalink) Old 08-05-2002, 08:30 PM
Bean Flicker
BlackTbird96's Avatar
Send a message via AIM to BlackTbird96
The FRPP heads are the SVO heads they will run you about $900 a piece a head and I think its about $1800 for the intake for those heads. So if you got the money go for it. They flow better the PI heads and wont affect your compression ratio.
BlackTbird96 is offline
