stalls when getting on freeway. - TCCoA Forums
post #1 of 9 (permalink) Old 04-01-2013, 04:16 PM Thread Starter
96 t-bird 4.6 v8. the car drives fine but whenever I have to punch it, it acts like its not getting any fuel. whenever i've been able to hear this, it sounds like the fuel pump is dry pumping. I already changed the filter and its seems to have helped a little but the problem still persists. also this ride has horrible fuel mpg's.
eddiecurbside is offline
post #2 of 9 (permalink) Old 04-01-2013, 04:27 PM
Moderator & Teksid Whore
guitar maestro's Avatar
please list any and all maintenance you have done to your car. (aside from fuel filter).
guitar maestro is offline
post #3 of 9 (permalink) Old 04-01-2013, 06:45 PM
renello79's Avatar
Not just maintenance, include mods to. Mods are just as important as performed maintenance as well as what hasn't been done.
Phrum Steve
http://photobucket.com/SCno1
sold, sadly
renello79 is offline
post #4 of 9 (permalink) Old 04-02-2013, 08:46 PM
nall_one's Avatar
did you put the fuel filter on flowing the right way?
otherwise yes, have you done 'the usual'
nall_one is offline
post #5 of 9 (permalink) Old 04-02-2013, 09:37 PM
Mgino96tbird46's Avatar
Any codes?
Mgino96tbird46 is offline
post #6 of 9 (permalink) Old 04-03-2013, 03:20 PM Thread Starter
all i've had a chance to do is the fuel filter and it has no codes.
post #7 of 9 (permalink) Old 04-03-2013, 03:29 PM
Maybe your fuel pump is failing? Mine stopped holding pressure after shut off by 130,000 miles. My current pump, a Walbro GSS 340 (255lph), does.
post #8 of 9 (permalink) Old 04-03-2013, 04:28 PM
Red face
I would check fuel pressure first. How bad was the old filter you took off. If you hear the pump starving for gas, you may have a bad fuel level sensor showing you have more fuel then you do. Fuel pump will cut out and do alot strange stuff when going bad and not throw any codes.
lcortinas is offline
post #9 of 9 (permalink) Old 04-03-2013, 06:29 PM
nall_one's Avatar
never a good idea to run a fuel pump low on fuel either, they use the fuel to keep cool and lubricated.
definitely good to start with fuel pressure, maybe toss a can of sea-foam in their for [email protected]# and giggles.
also, how many miles are on said bird, if its over 150-200k then the pump is most likely dead/dying. especially if the filter was neglected.
plus if the filters are neglected long enough, they sometimes break down and dump filter material and gunk into the rail and injector screens. if those screens get packed with that stuff they of course wont work.
nall_one is offline
