Super- Super Coupe build thread - TCCoA Forums
post #1 of 126 (permalink) Old 04-15-2013, 12:09 PM Thread Starter
Well guys the weather is finally warm enough to start my M90 Cobra motor install into my 94 SC. So far ive pulled the entire SC powertrain including all related wiring harnesses. Just the boring stuff for now.
Powerwashed engine compartment
Installed the new "custom" Cobra harness and PCM
Installed "custom" adapter from the EEC harness to 94 SC dash
Installed 1.25 Addco front sway bar
Mark VIII coolant reservoir
Soon to be done-
Install K-member spacers(.25) and sway bar mounting bracket spacers(.50)
install Cobra starter harness and Battery harness- with necessary adjustments
modify Cobra PS pump to use EVO sensor
Install Cobra motor for mach ups.
http://s1341.photobucket.com/user/le...?sort=3&page=1
Lee billing is offline
post #2 of 126 (permalink) Old 04-15-2013, 02:08 PM
Platoribs's Avatar
Subscribed.
Platoribs House of SHO
95 SHO MTX 73K grn/tan
93 SHO MTX 175K blu/blk
92 SC M5R2 98K Red/Grey tweed ->Blk Cloth SC
89 SC M5R2 112K Blu/Blk Shiny Cobra's! *coming out party, May 20th 2012* Now with moar suspension, brakes and slave cylinder...
91 SC M5R2 100K blk/blk tweed building
86 Mercedes-Benz 300e
Platoribs is offline
post #3 of 126 (permalink) Old 04-15-2013, 02:27 PM
cobra R Thunderbird's Avatar
Awesome! Where did ya scoop the motor & trans from?
2001 GT BULLITT #00762 stock
post #4 of 126 (permalink) Old 04-15-2013, 03:16 PM Thread Starter
I found it collecting dust in a storage room at Roush. I worked in the performance division there for about 7 years. Didnt pay that great but it had its perks.
I wont even tell you what I paid for it. The trans was not attached to the engine I bought that seperately from Roush. It already has a hydraulic slave in it so its ready for the SC set up.
post #5 of 126 (permalink) Old 04-15-2013, 03:31 PM
Thats freakin sweet. & now you have me curious of what you paid for it lol.
post #6 of 126 (permalink) Old 04-15-2013, 04:01 PM
S4gunn's Avatar
Q: Did you fabricate your own M90 => 5.0 lower intake?
Also, from what I've read, lots of folks seem to believe that the M90 is undersized for a 302.
Is this just a case of "its hard to beat cheap" or do you think their concerns are just a bunch of hooey?
-g
http://goo.gl/csaet4
S4gunn is offline
post #7 of 126 (permalink) Old 04-15-2013, 04:06 PM
What 302?
post #8 of 126 (permalink) Old 04-15-2013, 04:10 PM
S4gunn's Avatar
What 302?
Nevermind, I though that the Cobra engine he was using was a 5.0 (94-95) and not a 4.6.
You guys recognize V8s better than me.
-g
Ahh, I see now that it's got a distributorless ignition system. Hence, more than likely a 4V Cobra 4.6L engine.
S4gunn is offline
post #9 of 126 (permalink) Old 04-15-2013, 06:37 PM Thread Starter
-g
Well for those who say that the M90 is too small for a 4.6 when I worked at Roush we were bolting M90s to 4.6 3 valves and gaining 120 hp and about the same or a little more torque. This is something you can look up on the internet for verification. Just because it won't boost 12 psi doesn't mean that its too small. I would think I can get 8 psi and be verry happy.
post #10 of 126 (permalink) Old 04-15-2013, 06:57 PM
dDUBb's Avatar
-g
Its a prototype engine built by Ford .. not some do it yourself hack job, I have spare parts lying around.
dDUBb is online now
post #11 of 126 (permalink) Old 04-15-2013, 07:05 PM Thread Starter
You have spare parts for my motor and blower setup ? We may have to talk
Nevermind. I misread the first time.
post #12 of 126 (permalink) Old 04-15-2013, 08:05 PM
Moderator & Teksid Whore
guitar maestro's Avatar
Not only is 8psi nothing to sneeze at, if you can drop the ACTs down within a few degrees of ambient, those 8psi could possibly translate into "12psi's" worth of non-intercooled actual airflow. After all, it's all really about airflow when it comes to making power. Use an ice-water-to-air intercooler, and any tiny supercharger can move some hefty amounts of air mass.
guitar maestro is offline
post #13 of 126 (permalink) Old 04-15-2013, 08:13 PM
Platoribs's Avatar
MP is now providing Gen 5~6 abradive rotor pack coating improving effeciency, lowering temps. Should have this delivered in a week or two.
post #14 of 126 (permalink) Old 04-15-2013, 08:41 PM
yup, there's always lots of little things that can improve efficiency that will show up at the rear wheels. It's just no one [few] bothered to pay attention in physics class in high school/college. I'm sure ceramic bearings for the high rotational speeds (> 12,000 rotor RPM using a 1:2 gear-up ratio and a 6k engine redline) of the rotors could free up a few HP here and there. If it takes even 5 less HP to spin the rotors, it ends up at the wheels. Superfinish the rotor gears, another couple HP there.
post #15 of 126 (permalink) Old 04-15-2013, 10:25 PM Thread Starter
You are a wealth of information when it comes to anything with numbers and physics. I see why you are a math teacher.
There are alot of things that I would love to do to this thing but I need to take it one step at a time. Right now I'm just focusing on getting it in the car and drivinig down the road. Even if its not as efficient as it can be it will be a big step up from the SC
V-6. For right now i will put a Meth Inj kit on it and get it tuned.
Lee
post #16 of 126 (permalink) Old 04-15-2013, 10:37 PM
Platoribs's Avatar
yup
Math teacher huh, my Dad taught Mathmatics for 36 years at SIU.
Kudos GM, teaching is noble.
post #17 of 126 (permalink) Old 04-16-2013, 10:20 AM
I do have to say the roush 4.6 is going to be fun having some thing like that in a thunderbird or cougar it would make every one look twice. Once seeing the smiling look that is being seen. The second is looking at the car.
95mercxr7 is offline
post #18 of 126 (permalink) Old 04-16-2013, 11:21 AM
Can't wait to see how this one turns out. Good luck with your build, lots of helpful folks and info on this forum.
post #19 of 126 (permalink) Old 04-16-2013, 04:59 PM Thread Starter
Nothing big happened today just bolted up the Mark VIII PS pump to retain the EVO sensor. I was gonna just put the sensor on the cobra pump but no luck. They are different pumps, so the Mark VIII pump got the Cobra pulley and DONE.
Removed the high pressure line and return line to install the SS Braided lines.
Flipped the motor upside down and removed the pan just to inspect a little. This motor has been sitting for a long time so I wanted to see the cylinder walls and look for any kind of moisture damage. There was none. The inside of this motor looks brand new. There is hardly any witness marks in the cylinders to indicate piston travel.
I think this motor is gonna be sittin in the car very soon. Im gettin antsy but dont wanna skip a step.
Lee
post #20 of 126 (permalink) Old 04-17-2013, 07:28 AM
Platoribs's Avatar
This is very encouraging information, I've had a newly rebuilt 3.8 SC engine sitting inside and outside for the past four years. Its sealed (tape over exhaust ports) but I was concerned about rust forming inside and no way to address cleaning prior to install/start up.
Is there any type of additive I could use on start up besides just dumping the first oil change at early miles/hours?
Chris
post #21 of 126 (permalink) Old 04-17-2013, 12:15 PM
MaleWhore
smokymance's Avatar
Glad to see another local member doing these swaps! you are so close! i live north of you by the end of M5 and go to ford livonia for work all the time!!!!! id love to see the car soon!
smokymance is offline
post #22 of 126 (permalink) Old 04-17-2013, 12:39 PM
CometGSR's Avatar
Yeah, I am just down the road. I would love to check this out.
-=James
1995 Ford Thunderbird V8
SCT Tuned by Amercian Motorsport, Mustang PBR, FRPP 3.73 gears, Modified Trak-Lok, Steeda UDP, K&N Panel, 1990 SC Seats, 2.5" Single Exhaust/Magnaflow Hi-Flow Cats, Michelin Pilot Sport A/S +, Windstar wheels, RichardM Intake, Kenwood KDC-HD552U HD Radio, 2800 stall DirtyDog Marauder TC, J-MOD, 2002 Grand Marquis transmission, DynoTech Driveshaft, AeroForce Interceptor Scan Gauge, Griffin Super High Capacity Radiator, 180* Thermostat, Cobra steering wheel, 6000K HID, Clear Corners Getting a makeover Spring 2015
http://www.fordthunderbird.net - For Pics and more!
CometGSR is offline
post #23 of 126 (permalink) Old 04-17-2013, 01:12 PM
MaleWhore
smokymance's Avatar
We can all meet up! summer is here! ( i think!)
post #24 of 126 (permalink) Old 04-17-2013, 01:45 PM Thread Starter
On the 3.8 i would try priming the oil pump. I dont know of any additive, other than disassembly and putting assy grease on everything.
I work at the Livonia Trans Plant on Plymouth Rd. When ur down this way PM me and i can show you.
PM me whenever, I work afternoons tho. Right now it just looks like a SC with no engine, and the garage im workin in is kinda tight. Someday ill be able to afford a huge garage and a lift. I have made extra effort to make it look all factory.
This project will hopefully be done by the middle of May so it should be prime cruisin time.
post #25 of 126 (permalink) Old 04-17-2013, 02:15 PM
MaleWhore
smokymance's Avatar
LOL i go to ATNPC all the time...i actually was there yesterday! Ford is our customer, i work with external trans controls! im there at least once a week!
post #26 of 126 (permalink) Old 04-17-2013, 03:51 PM Thread Starter
Well technically I work in the ATNPC building. Most people dont know what that is so I say the plant. I work in RWD developement garage. I work afternoons so i dont get in until 2 but if your here ask for me someone will find me.
Lee
post #27 of 126 (permalink) Old 04-17-2013, 10:38 PM
Was looking through your pics and figured I'd answer your question
Square peg round hole ?
That's C156. in 1994 it was a square connector and from 95-97 it was changed to a round connector. The circuits are all the same, you just need to splice a matching pigtail onto either the headlight harness or EEC harness
post #28 of 126 (permalink) Old 04-17-2013, 10:51 PM Thread Starter
More boring stuff today. Just wired in my OBD II DLC connector, the SC did not have EEC V it was EEC IV with the DLC connector under the hood. Having to include this in my adapter harness for the EEC harness to the Dash harness made it kinda ugly but it all functions as it should as far as i can tell at this point.
Got the battery harness to starter installed but cant route it correctly until the motor is in. Had to change a couple connectors to match the bird harness but for the most part an easy install. The positive battery cable clamp does not fit the way i would have liked it but its not bad. I guess a Cobra harness wasn't made for a thunderbird. Hooked it to the distribution box and gave it a key on. The fuel pump cycles so i guess thats a good sign.
Hoping to have the engine sitting in the compartment this weekend.
Here's some pics.
http://s1341.photobucket.com/user/le...tml?sort=3&o=2
http://i1341.photobucket.com/albums/...ps70b2f2ae.jpg
http://i1341.photobucket.com/albums/...psa306ae89.jpg
post #29 of 126 (permalink) Old 04-17-2013, 11:34 PM Thread Starter
I already made an adapter harness from a donor at the junkyard. Here's my question. There are 2 circuits on the 94 square connector that are not on the round connector. One is a circuit 57 which is grnd so I tied it into the other circuit 57. The one that confuses me is the extra circuit 361 I think it is. Its a red wire which in the 94 it supplies key on power to the pcm relay to close the circuit. I am not sure if the CCRM in the 96 needs this or if it gets it from one of the other circuits. I think I got it figured but I really wanna hear an experts opinion. Thanks in advance.
post #30 of 126 (permalink) Old 04-18-2013, 12:43 AM
Is that one of the prototype B-head M-90's? Like the SVE bird?
