question before i put on the pi heads - TCCoA Forums
post #1 of 8 (permalink) Old 04-24-2013, 05:50 PM Thread Starter
I have a feeling that the stock fuel pump will not be fesable or might not work with the pi heads and the pi intake i am getting ready to install.
My question is will this fuel pump work JEGS Performance Products 159041.
Or would some other fuel pump work well with it.
I have read majority of the posts but it didnt give much clarity or went over my head.
What i wanted to ask what is the most reliable fuel pump for the pi top swap on a npi engine.
I am sorry for the confusion but i wanted to ask and get feed back to halp me get the right one thank you for the replies
95mercxr7 is offline
post #2 of 8 (permalink) Old 04-24-2013, 05:58 PM
Stock pump is perfectly adequate for stock PI stuff
post #3 of 8 (permalink) Old 04-24-2013, 06:38 PM
rmfk13's Avatar
What he said
Rob
rmfk13 is offline
post #4 of 8 (permalink) Old 04-24-2013, 06:55 PM
Moderator & Teksid Whore
guitar maestro's Avatar
a properly working stock fuel pump is adequate. If it's on its last legs, it or any other weak fuel pump can leave you stranded. Your original fuel pump is now ~19yrs old if you haven't already replaced it before.
BTW, that jegs pump is likely just a re-branded Walbro 190lph pump that you can get cheaper
http://www.autoperformanceengineerin...html#ford_apps
guitar maestro is offline
post #5 of 8 (permalink) Old 04-24-2013, 08:38 PM
Lol my fuel pump is original.
lcortinas is offline
post #6 of 8 (permalink) Old 04-24-2013, 08:53 PM
if it's old enough to be in college, it's pretty old, lol.
post #7 of 8 (permalink) Old 04-26-2013, 07:01 PM Thread Starter
It is a new one in a way it was replaced when the relay broke on my dad it kept runing the pump when he shut the car off and caused the pump running.
It was replaced with the same type of pump from the dealer that i worked at when i was in virginia.
post #8 of 8 (permalink) Old 04-26-2013, 07:03 PM Thread Starter
Oh i forgot to say thank you for the input when i was reading the pi head swap post write up. i had to ask.
Thank you again for the input and the added information
