priming a Cobra motor - TCCoA Forums
post #1 of 25 (permalink) Old 04-26-2013, 06:54 PM Thread Starter
Anybody got any ideas on how to prime the oiling system on a DOHC motor. The only way I can think of is pullin the spark plugs and crankin the engine. I'm not sure that the startet will crank fast enough to build any pressure. Lookin for some ideas. Just pull the distributor and use a drill on the pump driveshaft......LOL
THANKS
LEE
Lee billing is offline
post #2 of 25 (permalink) Old 04-26-2013, 08:22 PM
I think RaceCougar could hook you up; look at his gallery.
EDIT: Dang, you guys are lazy...
http://forums.tccoa.com/showpost.php...59&postcount=2
post #3 of 25 (permalink) Old 04-26-2013, 08:46 PM
1996Project-bird's Avatar
If you hold the gas pedal to the floor the car will crank but not fire up. Thats how I did it with my PI, but the DOHC may be (probably) a different animal.
1996Project-bird is offline
post #4 of 25 (permalink) Old 04-26-2013, 08:49 PM Thread Starter
You are not the first person to say that so I think that's what I'll do. I just thought pullin the plugs would unload everything and give it a few more RPM's to build pressure.
Lee
post #5 of 25 (permalink) Old 04-26-2013, 09:33 PM
rmfk13's Avatar
Do not do that! Your car might fire up and boom goes the motor, trust me I've watched it happen. Unlplug the coils, and pull the fuse for the fuel pump then crank it for 30 seconds, off ten then repeat a few times, do this with a battery charger on the car so you don't sap the battery. The RPMS of the starter will be plenty enough to build oil pressure and will help seat the piston rings. That's the correct way to do it.
Rob
rmfk13 is offline
post #6 of 25 (permalink) Old 04-26-2013, 11:02 PM
If I don't borrow my engine builders primer. Then I like to do what you are thinking. Pull the plugs so there is less pressure on the bearings and I also unhook the crank and cam sensors and trip the inertia switch so no fuel sprays or plugs try to fire then crank it with the starter.
1995 SC------------------1994 SC----------------1993 LX
Black----------------------Red----------------------Grey
3.8-------------------------3.8w/bent rod---------5.0
4R70W--------------------M5R2--------------------AOD
2.4 AR in works---------2.0 Auto Rotor---------N/A
24psi----------------------15+----------------------none yet
450RWHP----------------322RWHP -------------who knows/who cares
[email protected]@[email protected]
BLOWN38 is offline
post #7 of 25 (permalink) Old 04-26-2013, 11:06 PM
Moderator & Teksid Whore
guitar maestro's Avatar
here's one way.
Originally Posted by Black35thGT
Get a cheap garden sprayer, fill it with oil, and plumb it to the port for the oil pressure sensor. Pressurize tank, turn the engine over by hand, repeat a couple times, pop a valve cover off to make sure you have oil to the lash adjusters/cam bores.
http://www.harborfreight.com/1-1-4-q...yer-95692.html
guitar maestro is offline
post #8 of 25 (permalink) Old 04-27-2013, 08:13 AM
I just replied to your PM, Lee. Here's what I use to prime new engines before the first firing.
The Accusump is just for priming the engine in the XR7 before regular startup. It doesn't have enough capacity to fully prime a fresh rebuild. Like I said, on your setup, you could prime through the oil sending unit port, or the port directly below it.
post #9 of 25 (permalink) Old 04-27-2013, 08:44 AM Thread Starter
Thank you guys for all your help. Much appreciated.
Lee
post #10 of 25 (permalink) Old 04-27-2013, 12:15 PM
I have a relocation kit for my filter, can I just plug the port from the sump into the hose that goes to the block to do the same thing to prime it?
Second, what is a good break in oil for a new 4.6 and how long until you change it out for regular oil?
post #11 of 25 (permalink) Old 04-27-2013, 01:16 PM
That is a lot cheaper than an accumulator, as well.
I've used a filled accumulator, pressurized with air, to bring up oil pressure on several engines over the years...
It's especially nice to do before you start timing heads.
post #12 of 25 (permalink) Old 04-27-2013, 04:41 PM
Yes.
Viscosity will depend on your clearances, but you'll likely want to use a conventional 5W-30 oil for break-in. I'd suggest changing it after seating the rings, then again after 500 miles. At 1,000 miles you should be able to switch to synthetic. Of course, this depends on what ring material you're running, too.
Yep. The bug sprayer method works really well for how little it costs. My little 1-1/2 quart accumulator is perfect for bringing the engine up to ~25 psi before firing, but a fresh build requires a heck of a lot more pressurized oil than that to fully prime it.
post #13 of 25 (permalink) Old 04-27-2013, 04:58 PM
jhiland32's Avatar
I learned something today.
Jason H.
Mods:
jhiland32 is offline
post #14 of 25 (permalink) Old 04-27-2013, 05:23 PM
Toure Cole's Avatar
Toure Cole is offline
post #15 of 25 (permalink) Old 04-28-2013, 02:22 PM
Originally Posted by Toure Cole View Post
I hate YouTube videos like this. He doesn't actually show what he did to route the hose to the motor at the oil filter adapter. Don't matter to me, but I'm sure others would be interested in how to do this.
post #16 of 25 (permalink) Old 04-29-2013, 06:11 AM
The engine sill not fire if the gas pedal is held to the floor. Also, cranking it will not build any pressure.
na svt is offline
post #17 of 25 (permalink) Old 04-29-2013, 07:00 AM
rmfk13's Avatar
With some newer engines this is true, its called clear flood mode. I've done it and I've watched other people do it, bottom line is why risk it? Unplug a few connectors and pull a fuse or two, it only takes a few minutes as opposed to nuking a motor and having to spend a couple of hours pulling it and reinstalling one. Also explain to me how cranking and engine will not builld pressure, since the oil pump is mounted on the crankshaft, and what spins the when you crank the motor? That's right the crankshaft, you will build pressure, not the ammount you need when then engine is running, but enough to oil the engine and all its moving parts. I only do this for a living, but what do I know right?
Rob
rmfk13 is offline
post #18 of 25 (permalink) Old 04-30-2013, 07:47 PM
Holding the accelerator to the floor is the standard way to clear an engine from being flooded with gas.
A carb engine won't build vacuum, so no major gas; the computer emulates this for us because it's always worked.
As long as your TPS and wiring are perfect, there's no worry whatsoever with using that method to keep your new engine from starting.
Of Course, if the TPS intermittently fails, or you twitch your foot, it starts at wot.
On a 96-97 4.6 car, pulling fuse 15 in the box under the hood will prevent the eec from working.
This prevents the coils from firing; I don't think the injectors fire. YourCarMayVary.
post #19 of 25 (permalink) Old 04-30-2013, 09:22 PM
I always pull that and the EEC fuse to be on the safe side as well. WOT no-starts do work but in that off event (like accidentally leaving the TPS disconnected) it's well worth taking away variables.
post #20 of 25 (permalink) Old 05-01-2013, 09:19 AM
Anyone know the thread size on the bottom port of the oil filter housing?
post #21 of 25 (permalink) Old 05-01-2013, 12:54 PM
Black_Cat's Avatar
Pull the fuel pump relay and turn the motor over for about 20 seconds, you'll be good.
2011 BMW X5 35i Premium Package
2009 BMW 535i ///M Sport Package
Black_Cat is offline
post #22 of 25 (permalink) Old 05-01-2013, 02:09 PM
If it is plugged with a pipe plug you can be assured its an NPT thread. Possibly 1/4".
post #23 of 25 (permalink) Old 05-01-2013, 03:45 PM
copy thank you!
post #24 of 25 (permalink) Old 05-01-2013, 07:02 PM
nall_one's Avatar
i saw somebody one time with a oil filter relocation adapter hooked to a gallon container that you used compressed air to pressurize. it forced oil up and out into the motor.
it was pretty neat, seems like the same sort of thing that bug sprayer dose but this one was able to build 80psi on the dash gauge, and oil spit from pushrods and things like its supposed too.
pretty sure the guy made it with whatever he had lying around.
nall_one is offline
post #25 of 25 (permalink) Old 05-01-2013, 08:14 PM
Yep, same concept. You can also use a drill and a shaft driven oil pump.
I want to say it's 1/8" NPT, but it's been a long time, so don't hold me to that.
