4.6 engine harness - TCCoA Forums
post #1 of 4 (permalink) Old 05-02-2013, 04:28 PM Thread Starter
4.6 engine harness
I'm replacing the wire loom and sleeves on my engine wire harness as well as extending wires for sensors. I was able to label everything on the harness but these two. What do they go to? I don't have my diagram book with me, but if I had to guess...the first one goes to one of the coolant sensors and the other is for the EGR or A/C???
This is located between injector 1 and 2 and the two wire colors are black/white and red/white:
This is bundled with an A/C connector and the crankshaft position sensor. The two wire colors are brown/pink and red:
post #2 of 4 (permalink) Old 05-02-2013, 04:54 PM
The Great Obucina's Avatar
would #1 be the AC compressor cutout for WOT?
"Booyah". Stu Scott.
The Great Obucina is offline
post #3 of 4 (permalink) Old 05-02-2013, 05:37 PM
1 is for the gauge coolant sender
2 goes to the EGR vacuum regulator
post #4 of 4 (permalink) Old 05-02-2013, 06:07 PM Thread Starter
Thank you Matt
