Air filter to work with Cobra R hood? - TCCoA Forums
post #1 of 10 (permalink) Old 05-08-2013, 02:57 PM Thread Starter
I'm looking to increase the air flow on my '95 NPI 4.6L T-Bird. I have the Cobra R hood, with the two front induction slots. I found a K&N filter off of a Corvette that looks to be perfect. I would like to move the MAF and air sensor (? From stock filter box) up to the throttle body and put the filter in front. The MAF would come right before the TB and the sensor would be installed in the neck of the filter. I also have cut out rubber inserts for the induction slots for rainy days. Would this work? Sorry I couldn't post pics. Below is a link to the filter.
http://www.knfilters.com/mobile/mPro...?&prod=rp-5135
'95 "Black Widow" Thunderbird LX 4.6L V8
-Muffler/Resonator Delete
-Cold Air Intake (AutoZone plastic homemade)
-Magnum Crankcase Vent Filter (for looks)
-Accel Coil Packs -MSD Wires -Accel Spark Plugs
DD, nothing too special.
PerfTBird2012 is offline
post #2 of 10 (permalink) Old 05-08-2013, 03:39 PM
S4gunn's Avatar
I'm not sure that this is going to do much for you other than make more noise and suck $137 out of your wallet.
Q: Is your air filter really the point of restriction in your car? Have you hooked up a vacuum gauge to your manifold to confirm if this is true?
Q: That air filter seems like its going to suck air from all directions and not just from your fender well. If anything, this will mean higher intake air temps (and less powah) than from your stock air filter position.
http://goo.gl/csaet4
S4gunn is offline
post #3 of 10 (permalink) Old 05-08-2013, 04:17 PM Thread Starter
Even with the filter placed in the air channel under the hood/above the engine? That would eliminate the intake tube and provide straight cool air flow.
post #4 of 10 (permalink) Old 05-08-2013, 04:34 PM
dDUBb's Avatar
Very bad idea. The MAF is calibrated to have a certain amount of pipe between it and the throttle body .. this would not be a good modification.
dDUBb is offline
post #5 of 10 (permalink) Old 05-08-2013, 04:49 PM
S4gunn's Avatar
It's not laminar flow. If I understand how that fat mushroom will be oriented in your planned position, the air is not coming in across the hood and into the filter directly b/c there's a cap at the top of the filter. Instead, the air will be going across the hood, through the nostril hole in your hood, and then is sucked at a 90 degree angle into the air filter (comes in on the sides). The air could just as easily come from the sides and down from the hot engine since as you well know -- heat rises.
One thought I had to get cooler air was to flip my airbox upside down, cut a hole in my hood, and put a small scoop on the hood to direct air downwards and get the ram air effect.
- It would have looked hideous but who cares? It's a $500 car.
- The only thing that stopped me was that I never found a suitably hideous looking (and cheap scoop). I probably wasn't looking hard enough at home depot.
-g
S4gunn is offline
post #6 of 10 (permalink) Old 05-08-2013, 06:34 PM
-g
A 'bullet' trash can lid, the spring loaded door type; with the spring loaded door removed.
That's pretty hideous, IMHO.
post #7 of 10 (permalink) Old 05-08-2013, 06:52 PM
S4gunn's Avatar
http://www.lowes.com/pd_12599-131-L2...o=Dryer%20vent
$7.97 was too rich for my blood
Since my other drivers (the short ones) were complaining that they couldn't see over the 4" (at the highest point) DIY cowl hood on some of the turns @ Sears Point (road goes up and then takes a sharp right), I think that might go away... and the hood scoop might make a comeback.
http://www.gunn.com/images/tbird_3rdrace3.jpg
-g
PS. Your idea of a bullet trash can is intriguing but I think the Star Wars R2D2 thing has already been done to death in Lemons and I'm not willing to go full-nerd.
S4gunn is offline
post #8 of 10 (permalink) Old 05-08-2013, 06:58 PM
Moderator & Teksid Whore
guitar maestro's Avatar
very bad idea like everyone has said.
the intake is not the bottle neck in your engine---it's the intake manifold and cylinder heads. <----read that about 100x until it sinks in.
But then again, if you know sooooo much and your mind is already set, let's see the darn thing happen.
guitar maestro is offline
post #9 of 10 (permalink) Old 05-08-2013, 09:19 PM Thread Starter
Thank you very much. Your answer was all I needed. I'm 19 and a firefighter and don't spend all my free time on cars. So I appreciate your straight forward, non sarcastic answer to help a curious member.
post #10 of 10 (permalink) Old 05-08-2013, 09:25 PM
Question asked. Question answered. Answer accepted.
I don't see any reason for this thread to drag on.
Click.
