timing chain tensioner - TCCoA Forums
post #1 of 9 (permalink) Old 07-19-2013, 09:27 AM Thread Starter
I am replacing the lash adjusters and timing chains ,although they seem ok,on my 95 T-bird 4.6 and I am not sure which timing chain tensioner goes right and which goes left,I may have inadvertently switched them.they are not marked and they seem to be identical,is the internal valving different or what?
palian is offline
post #2 of 9 (permalink) Old 07-19-2013, 10:48 AM
You'll notice there is a bit of a lip in that area designed to hold them away from the block. Install them so the lip is facing the block and the flat part is facing the timing cover.
post #3 of 9 (permalink) Old 07-26-2013, 09:29 PM
Moderator & Teksid Whore
guitar maestro's Avatar
guitar maestro is offline
post #4 of 9 (permalink) Old 07-26-2013, 10:15 PM
Oh derp, I was thinking guides. The tensioners themselves are marked L and R.
post #5 of 9 (permalink) Old 07-26-2013, 10:52 PM
...unless he has some aftermarket units, which may or may not be labeled at all.....
post #6 of 9 (permalink) Old 07-27-2013, 12:21 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
I was under the impression that most aftermarket units were interchangeable side to side. Better check with manufacturers catalog just to be safe.
-Rob
Rob is offline
post #7 of 9 (permalink) Old 08-01-2013, 03:02 PM Thread Starter
checked different autoparts stores
checked different autoparts stores and they all list a left and a right but the tensioners I have are not marked they are identicle.I just went ahead and installed them, the engine is running fine and sounds fine.
palian is offline
post #8 of 9 (permalink) Old 08-01-2013, 06:51 PM
Hope you did the valve seals too!
tbirdguy is offline
post #9 of 9 (permalink) Old 08-02-2013, 11:29 AM Thread Starter
no didn't do valve seals,engine does not smoke when I start it up,should i have?
palian is offline
