Colder plug - TCCoA Forums
post #1 of 7 (permalink) Old 08-01-2013, 12:44 PM Thread Starter
Colder plug
Found that a colder NGK Plug is TR6, from an older thread. Is this correct?
All my spark plugs are chalky white so im thinking I need a colder plug.
TBIRD9491 is offline
post #2 of 7 (permalink) Old 08-02-2013, 06:00 AM
A TR6 is a little colder than stock. Chalky white plugs aren't any indicator of incorrect heat range. You need to look where the color is on the ground strap to determine where you're at in regards to heat range.
post #3 of 7 (permalink) Old 08-02-2013, 09:11 AM Thread Starter
The whole ground strap is chalky white
post #4 of 7 (permalink) Old 08-02-2013, 04:20 PM
Once again, that doesn't give you any information in regards to heat range. Are you losing any coolant?
EDIT: If you're trying to read heat range on old plugs, don't bother. Install a new set, make a pass, shut it down immediately, and read them.
post #5 of 7 (permalink) Old 08-02-2013, 06:39 PM
Good plugs on these cars look like lean plugs on older cars.
They run real close to optimum if nothing's wrong.
Odds are, you have a vacuum leak, unless you've replaced ALL of the vacuum lines; after 19 years, they're bad somewhere.
post #6 of 7 (permalink) Old 08-02-2013, 07:21 PM Thread Starter
I returned them and got just tr55 because I remembered that I fixed my vaccume leaks while those plugs were in the car. Also my 02 went bad with those also. So im just going to run the tr55
post #7 of 7 (permalink) Old 08-02-2013, 09:15 PM
Check them at your next oil change, and you'll be able to get a good idea of how it's running.
Remember not to pull the plugs warm, unless you've coated them in anti-seize. There are 4 threads...
