Oil Pressure Switch/Sensor Information - TCCoA Forums
post #1 of 6 (permalink) Old 08-09-2013, 10:17 PM Thread Starter
I found the answer I needed deep within the archives of the search function (forums.tccoa.com/showthread.php?t=463), but it stands to be mentioned possibly chronicled somewhere else as well that the oil pressure sensor/switch is different between the 94-96 and the 97 or more simply put for those swapping motors from PI engines or mark 8's there is a difference between the sender for a vehicle with a low oil pressure light (97 thunderbird/93-98 mark viii) and a vehicle with gauge (even though it's a dummy gauge). Just something I had long forgotten and freshly needed to know. If this is already well known then mods feel free to delete this thread.
post #2 of 6 (permalink) Old 08-10-2013, 10:59 AM
IIRC, the wrong sensor will show full oil pressure with KOEoff, then disappear when you start it.
Is all this in the wiring to the 97 dash cluster, and a cluster swap will fix it? Or is the 97 dash harness different?
post #3 of 6 (permalink) Old 08-10-2013, 02:35 PM
Swap clusters to fix it? Just swap the sender lol
post #4 of 6 (permalink) Old 08-10-2013, 02:56 PM
I just reread this, And realized my 97 only has a Light.
D'oh!
This will only be important if I swap clusters.
I do really hate the 97 cluster, and key.
post #5 of 6 (permalink) Old 08-10-2013, 04:20 PM
Moderator & Teksid Whore
guitar maestro's Avatar
good call there, as I have a '97 and ordered an oil pressure sender from Rock Auto but know I'll have to cross reference it to see which one they sent me.
guitar maestro is offline
post #6 of 6 (permalink) Old 08-18-2013, 06:34 PM
If the sensor measures shorted on the bench, it will be correct for the 97 + MarkVIII; open will be for earlier cars.
Both are switches; but one is Normally Open and one is Normally Closed.
They flip to the opposite state on oil pressure; ~5-10psi.
If these freak out, hope it's a wiring problem; it's too late otherwise, lol.
Thinking about this, our circuit is: a short on pressure to ground, thru a 20 ohm resistor, thru the gauge.
If our <= '96 sensor shorts to the manifold (ground), there should be no change. An open is required to cause a gauge problem.
A 97 or Mark shorts to ground, the light comes on; BUT An open wire only shows on startup KOEO lamps. Maybe the eec is designed to look, IDK.
I was surprised to find this out about the 97 cars; I hadn't read that before.
The changes make sense; they actually made a 98 Mark.
Our promised '98 SC 4.6 would likely have had this switch as well.
