Deleting cruse control - TCCoA Forums
post #1 of 6 (permalink) Old 09-20-2013, 07:35 PM Thread Starter
TwoHaggard's Avatar
If one wanted to delete cruse control on 95 4.6 those vacuum lines comin for booster you can block off, but what about the one going into the inner fender into the car? Can u block that one or what does it go to thanks.
Project still in progress
Explorer engine, vortech v2,intercooled,bullit intake,derale power steering cooler, b&m trans cooler, oil filter relocation, cobra aluminum radiator, Walbro 255 Pump, Intrax 2in lowering springs, KYB front/back,,mark8 Driveshaft, 1.25Rear sway bar, 3:73 aluminum diff, TrackLok, Rear Diff Cover Brace, Sc Wheels 235/60s, Jmodd, Air Bags in Springs,Rear strut Bar,17in Mirror Blk CobraRs, Sc L Brackets, rear torsional load brace, kmember-frame brace, weightloss program, pbr dual pistons drilled/slotted, stainless lines , recaro seats, sct x4 DonL tuned
TwoHaggard is offline
post #2 of 6 (permalink) Old 09-20-2013, 08:43 PM
The one that goes into the passenger bay is the vacuum dump valve, and can be ignored if yhou're deleting cruise.
RalphP is offline
post #3 of 6 (permalink) Old 09-20-2013, 09:25 PM Thread Starter
TwoHaggard's Avatar
Passenger as in the inside of car right? Because the cruse an the lines I'm referring to are on the drivers side. That that dump line need pluged or anything?
post #4 of 6 (permalink) Old 09-20-2013, 10:29 PM
dDUBb's Avatar
The one that goes to your brake pedal ... no.
dDUBb is offline
post #5 of 6 (permalink) Old 09-20-2013, 11:29 PM
Hence the phrase "passenger bay" - yes, inside the passenger area of the car.
It goes to the dump valve on the brake pedal, and as such, only has "vacuum" when cruise is running.
RalphP is offline
post #6 of 6 (permalink) Old 09-20-2013, 11:29 PM
The lines are teed with the booster line, so just run a hose straight from the vacuum tree on the wiper cowl to the booster and toss the rest.
