Well there goes my 4v engine! - TCCoA Forums
 1Likes
post #1 of 43 (permalink) Old 10-25-2013, 03:12 AM Thread Starter
stay_unique_91's Avatar
On my way home from work last night I went at it with this 3v S197 mustang. First gear car ran like a bat outta hell, hit second and barked the tires and then the car just fell on its face. Horrible misfire and smoking like a train, had to get her towed home. Pulled all the spark plugs all were oil fouled on bank 1. Compression tested the engine and all of the cylinders on bank 1 had no compression. Pretty sure I made PTV. I dont know why it happened the car shifted at 6500 rpm like normal.
Being that I am sure the engine is done I've already started making plans.
- Teksid block
- Forged internals (crank, rods, pistons)
- Ported TFS heads from MHS (9.3-9.5:1 CR)
- Tork Tech Kit
- 2.8 Kenne Bell
- E85 w/ Meth
Buddy is selling his 2.8 KB said he would make me a killer deal on it. Would like to see in the 600whp range but we will see when we get there.
Shoot me some ideas on what you think. What I should do while I am there and things of that nature. Look for my up coming build.
Daily Driver - 2014 Ford Mustang GT 5.0 manual black on black. Stock for now.
Current Project - 1996 T-bird LX 4.6L: PI head swap, factory 3.27 TL, tuned by Don LaSota.
Retired Car - 1995 T-bird LX 4.6L: 4v swap plus Cobra goodies
stay_unique_91 is offline
post #2 of 43 (permalink) Old 10-25-2013, 08:42 AM
Mgino96tbird46's Avatar
You can run more compression, imo.
Mgino96tbird46 is offline
post #3 of 43 (permalink) Old 10-25-2013, 04:09 PM
Tbird1997's Avatar
Dang that sucks. Were you on the juice?
-Patrick
Tbird1997 is offline
post #4 of 43 (permalink) Old 10-25-2013, 04:18 PM
I can get u some trickflows there is no need to port them I made 735 rwhp on the 185 heads
Let me know if u need pricing
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
RobertP is offline
post #5 of 43 (permalink) Old 10-25-2013, 04:23 PM
Moderator & Teksid Whore
guitar maestro's Avatar
Yup, with E85 AND meth, you're just giving up free power with such a low compression ratio. Also get some good valvesprings
guitar maestro is offline
post #6 of 43 (permalink) Old 10-25-2013, 05:23 PM
post #7 of 43 (permalink) Old 10-25-2013, 08:38 PM Thread Starter
Rob pm me on the prices for the heads. In the coming weeks I will be purchasing the KB.
What kind of compression ratio would you think would be adequate, GM?
And no I wasn't on the juice lol. All motor.
post #8 of 43 (permalink) Old 10-25-2013, 08:41 PM
well Ricky just posted up how he's running 12:1 on 9psi in the supercharging forum. You should check out his thread. Run an air-to-water intercooler + meth + E85 and you can go HIGH. I'm an N/A guy, so my advice of going 14+:1 should not be heeded, lol.
post #9 of 43 (permalink) Old 10-25-2013, 09:53 PM
Ill price u heavy springs and standerd springs
Robert
10.75 @128.38
RobertP is offline
post #10 of 43 (permalink) Old 10-25-2013, 11:37 PM
ricky05uphs's Avatar
With a 2.8l KB.... I wouldn't go insane on compression. Your goal of 600hp should be pretty easy. Just make sure your fuel system is stout. I'm running 60lb injector and a 405 pump. I think around 525whp on e85 is all it will do.
95 4.6 Bird full PI swap daily driver, DD 2200 stall converter, Jerry chip, 80mm Maf.
Back in the day with a few other mods such as 3.73 (3.08's now), underdrive pullies(back to stock pullies now)and C&L upper and 70mm TB. [email protected]
96 Tbird FRPP/SVO blower 3.3 pulley, 70mm TB, 90mm maf, AIS w/2 nozzles,iron block with -3cc dish mark VIII pistons, stock pi heads/cams , DD 3800 stall converter, Built trans by Robertp, ported manifolds, nice exhaust, Cobra rearend with 3.73's, Mach 1 Breaks up front, SCT tuned by Robertp, and 60lbs injectors and 405lph pump. E85
2005 expedition 5.4 family vehicle
ricky05uphs is offline
post #11 of 43 (permalink) Old 10-27-2013, 08:27 AM
you might want to check with modular motors for the internals.
they have a 5.0 stroker kit, crank, rods, pistons, rings, bearings, and gaskets for around 2K and it's safe to 1000 rwhp.
when my friend builds motors for gt500's he likes to have 10 1/2-1 compression for gas motors.
mrt2you is offline
post #12 of 43 (permalink) Old 10-27-2013, 11:22 AM
10.5:1 is good on gasoline. But with the high octane of E85 + meth, the sky is the limit (practically).
I wanna see who has the manhood to do 15+:1 blown on 12+psi on E85 +meth injection + ice water-to-air intercooler
post #13 of 43 (permalink) Old 10-27-2013, 01:40 PM
You should totally do it.
post #14 of 43 (permalink) Old 10-27-2013, 01:56 PM
Never!!!!!
All I'll ever need is mother nature's own atmospheric pressure to whoop some a**!
post #15 of 43 (permalink) Old 10-27-2013, 10:18 PM Thread Starter
So I pulled the engine out today. I haven't gotten to totally tear it down yet. Got a late start to the day and ran out of sunlight...plus the buddy and I were watching football and drinking beer. lol. I did however get a chance to tear the valve covers off, check out what I found.
 photo CF378F7E-E04C-4087-A874-2E046A531F49-1740-00000222ACDE5ECF_zpsb7dde545.jpg
Thats from the passenger side head. The timing chain that connects the intake and exhaust cams.
post #16 of 43 (permalink) Old 10-27-2013, 10:32 PM
Dayum. I wonder if one of the cams siezed, or maybe even the sprocket shifted at high rpm (some B motors don't have a key installed from the factory)
post #17 of 43 (permalink) Old 10-28-2013, 12:07 AM
Or the chain just broke. Same thing happened to my dad's '96 Mustang Cobra one morning when my mom went to start it before going to work. That made me paranoid about B-headed 4.6's.
post #18 of 43 (permalink) Old 10-28-2013, 12:24 PM
That chain looks torn open; that takes a lot of force.
I'd pop the followers off with a screwdriver; I'm betting the non-driven cam is welded in place.
Grog6 is online now
post #19 of 43 (permalink) Old 10-28-2013, 12:56 PM
Well on the bright side, the bottom end may be alright. Pop that head off and see what the pistons look like. You may be able to get away with just a head swap and be back up and running.
post #20 of 43 (permalink) Old 10-28-2013, 03:01 PM
My thoughts exactly.
BTW is that a Mark VIII oil pan or the stock Tbird pan? I don't see the bung for the level sensor Marks use on the side?
post #21 of 43 (permalink) Old 10-28-2013, 03:03 PM Thread Starter
Unfortunately the pistons were not spared.
Photobucket Pictures, Images and Photos
post #22 of 43 (permalink) Old 10-28-2013, 07:56 PM
You were getting several hp out of the aluminum burning; holy crap!
Grog6 is online now
post #23 of 43 (permalink) Old 10-28-2013, 08:36 PM Thread Starter
I am in the processes of tearing it down to a bare block. I sold the intake manifold with all the goodies today to a friend with a Mark VIII. Put up the crank on craigslist and got a couple hits. All that money will be funding my new build. 2.8KB TFS 4.6 to come soon.
post #24 of 43 (permalink) Old 10-29-2013, 06:09 PM
I'm Jonesing: post up some more Engine Carnage Porn, with a better description of what broke!
We will not discuss how it broke, it could have happened anywhere; Carnage is carnage.
(I still can't believe the years-back mark-engine-torn-in-half pix; Now That's a freakin' malfunction, lol.)
It looks like you really leaned out...
Grog6 is online now
post #25 of 43 (permalink) Old 10-29-2013, 06:32 PM
MA Drag Race Team Coordinator
1MTNCAT's Avatar
And you were running how much spray???
Where are the spark plugs on those cylinders?
Steve
Nitrous 11.75 @ 114 MPH
1MTNCAT is offline
post #26 of 43 (permalink) Old 10-29-2013, 07:42 PM Thread Starter
During the time in which it broke I wasn't running any juice. When I did spray I was spraying 125 wet shot. I don't understand what your asking for on the spark plugs.
post #27 of 43 (permalink) Old 10-29-2013, 07:54 PM
Boost!!!
modularbird's Avatar
i think he just wanted to see a pic of them.
Blake
1996 thunderbird lx (the silver slut)
http://forums.tccoa.com/vbpicgallery.php?do=view&g=387
modularbird is offline
post #28 of 43 (permalink) Old 10-29-2013, 08:27 PM Thread Starter
Kind of late on that one. I already too everything in for scrap metal. Heads, pistons, chains etc. All I have left is a bare block.
post #29 of 43 (permalink) Old 10-29-2013, 08:55 PM
Spark plugs are in the middle of the chamber on 4v B Heads.
~Rick
TCCoA Sig
post #30 of 43 (permalink) Old 10-29-2013, 10:06 PM
Not even gonna at least describe the carnage to us? What a gyp!
