please help or point me in the right direction - TCCoA Forums
post #1 of 6 (permalink) Old 10-28-2013, 02:58 AM Thread Starter
I want to do the home made cold air intake,never pieced one together before also bought whats ment to work?i tried the search,does any one have a clear write up on this?
stang3191 is offline
post #2 of 6 (permalink) Old 10-28-2013, 02:58 AM Thread Starter
Sorry its also for a 95 4.6 factory intake.
post #3 of 6 (permalink) Old 10-28-2013, 05:17 AM
TwoHaggard's Avatar
I Have one for sale http://forums.tccoa.com/showthread.php?t=144200 I'll take $40 plus shipping, it's a popular set up for the 94/95
Project still in progress
Explorer engine, vortech v2,intercooled,bullit intake,derale power steering cooler, b&m trans cooler, oil filter relocation, cobra aluminum radiator, Walbro 255 Pump, Intrax 2in lowering springs, KYB front/back,,mark8 Driveshaft, 1.25Rear sway bar, 3:73 aluminum diff, TrackLok, Rear Diff Cover Brace, Sc Wheels 235/60s, Jmodd, Air Bags in Springs,Rear strut Bar,17in Mirror Blk CobraRs, Sc L Brackets, rear torsional load brace, kmember-frame brace, weightloss program, pbr dual pistons drilled/slotted, stainless lines , recaro seats, sct x4 DonL tuned
TwoHaggard is offline
post #4 of 6 (permalink) Old 10-28-2013, 08:59 AM
Do be aware that your car ALREADY has a cold air intake.
Before I stuffed a cone filter in there as a HAI (Hot Air Intake - don't believe me, stick your head under the hood after it's been running in July around here!), I'd pull the silencer, and switch to a low restriction air filter (yes, they make K&Ns for the stock air box!)
But do remember, for a 1995, that is NOT the restriction point. Before you worry about that much, study up on the PI swap. Or at least a 96/97 intake swap.
RalphP is offline
post #5 of 6 (permalink) Old 10-28-2013, 11:34 AM Thread Starter
ok cool thanks
post #6 of 6 (permalink) Old 10-28-2013, 02:08 PM
ogbird95's Avatar
You Could Look At Air Raid, They Have A Misc. Tube Kits That You could UseToGetRid Of The Violin case
ogbird95 is offline
