340Lph with stock fpr? - TCCoA Forums
post #1 of 5 (permalink) Old 11-05-2013, 09:04 PM Thread Starter
miller1995's Avatar
I got a good deal on a 340Lph fuel pump. Will I run into any issues with the stock fpr?
Bryan
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
post #2 of 5 (permalink) Old 11-05-2013, 09:12 PM
ricky05uphs's Avatar
It might work. When I put my 405lph pump in with the stock fpr it had 45lbs of fuel pressure at idle. I had to use a super coupe performance fpr to fix the problem.
95 4.6 Bird full PI swap daily driver, DD 2200 stall converter, Jerry chip, 80mm Maf.
Back in the day with a few other mods such as 3.73 (3.08's now), underdrive pullies(back to stock pullies now)and C&L upper and 70mm TB. [email protected]
96 Tbird FRPP/SVO blower 3.3 pulley, 70mm TB, 90mm maf, AIS w/2 nozzles,iron block with -3cc dish mark VIII pistons, stock pi heads/cams , DD 3800 stall converter, Built trans by Robertp, ported manifolds, nice exhaust, Cobra rearend with 3.73's, Mach 1 Breaks up front, SCT tuned by Robertp, and 60lbs injectors and 405lph pump. E85
2005 expedition 5.4 family vehicle
ricky05uphs is offline
post #3 of 5 (permalink) Old 11-05-2013, 09:48 PM
It may work but I bet the stock regulator can't keep up Also be leAry of some of the 340 as when fuel heats up there no better than a 255lph
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
RobertP is offline
post #4 of 5 (permalink) Old 01-09-2014, 09:00 AM Thread Starter
miller1995's Avatar
Thanks for the responses. I will keep an eye out for an fpr. The 340lph was a good deal so I picked it up instead of the 255lph I was planning on. This one looks to be a decent unit purchased from Anderson Ford. Here is a link to more info on the pump I've got.
https://www.superchargersonline.com/...726b3d75118fb4
Bryan
SOLD1998 Escort ZX2
post #5 of 5 (permalink) Old 01-09-2014, 06:12 PM
driller's Avatar
It'll work but the fuel pressure will be higher. You'll want an adjustable FPR to bring it back to normal.
driller is offline
