Radiator Fan Test - TCCoA Forums
post #1 of 4 (permalink) Old 11-10-2013, 06:11 PM Thread Starter
BIRDMANLX281's Avatar
Question Radiator Fan Test
my bird overheated last week,, my fan never came on. can't you just run a couple jumper wires to the battery to check it? like take it out and do it.. i even saw something about turning on the a.c and the fan was supposed to come on mine never did. thanks in advance..
lowered 1.5'' with vogtlands,, tokico ''blues'' on all 4 corners... 28% mirror tinted windows,, P.I.Intake swapped,, S.C side skirts and rear bumper..
BIRDMANLX281 is offline
post #2 of 4 (permalink) Old 11-10-2013, 10:55 PM
check the coolant temp sensor. they are like $7 at autozone... most likely your culprit.
mercury cougar
a few mods
sig has been shortened
94lxbird is offline
post #3 of 4 (permalink) Old 11-12-2013, 07:16 PM
Certainly. You can check both speeds with that method, as it's just a two-speed electric motor after all.
post #4 of 4 (permalink) Old 11-12-2013, 08:18 PM Thread Starter
ok,, thanks,,, i tested it today... and it did noting,, there was like 3 prongs,, i checked the end ones cause one had a + and one had a - and it did nothing either way..
