Preliminary Research on Mark VIII - TCCoA Forums
post #1 of 12 (permalink) Old 12-10-2013, 05:46 PM Thread Starter
Rude's Avatar
Send a message via AIM to Rude Send a message via Skype™ to Rude
Cool Preliminary Research on Mark VIII
I've been doing a bit of Googling to get some details on this. As some of you may remember, I had a 1996 AED T-Bird. But in January I'm getting a 1998 white Lincoln Mark VIII LSC. It has 77K miles and runs real good. No oil leaks or any problems. It has all the paperwork to show it was well maintained. So this is the new project. I'm lusting over a forced induction route like I did before, but I may stay NA. I'l probably stay NA though. I don't have the bucks I used to. It all has to fir under a stock hood like my AED Bird did. I need to stay California smog legal, so that can be the tricky part. The smog Nazis over here are nuts. I had some non CARB approved internals in the T-Bird and the Wermacht never caught on to that.
Suggested mods for NA with the most bang for the buck appreciated. Many things have changed since I sold the last car and I value you guys input. I know it's a wide open question, but I'm trying to get my head wrapped around the new project right now.
Rude is offline
post #2 of 12 (permalink) Old 12-10-2013, 06:49 PM
Moderator & Teksid Whore
guitar maestro's Avatar
guitar maestro is offline
post #3 of 12 (permalink) Old 12-10-2013, 07:11 PM Thread Starter
Rude's Avatar
Originally Posted by guitar maestro View Post
gears and converter
Which gears and converter do you recommend?
Rude is offline
post #4 of 12 (permalink) Old 12-10-2013, 07:44 PM
3800 stall on the converter, and for gears either 3.73s or 4.10s depending on how much highway driving you do.
post #5 of 12 (permalink) Old 12-10-2013, 08:02 PM Thread Starter
Rude's Avatar
How is the drivability on a torque converter like that?
Rude is offline
post #6 of 12 (permalink) Old 12-10-2013, 10:11 PM
depends who is gonna tune it, and it depends on what gears will be used. It's an evil triangle if you only focus on two. The less you focus on shelling out $$$ on getting a competent tuner to account for the changes, the worse it will be.
post #7 of 12 (permalink) Old 12-11-2013, 08:34 AM
Send a message via AIM to fkostyun
I'm toying with dumping the bird for an LSC myself - need something a tad more reliable.
fkostyun is offline
post #8 of 12 (permalink) Old 12-11-2013, 10:03 AM
Non intercooled vortech w meth injection, Imrc delete, some kind of exhaust, 373,s unless you like more (I really don't for a street car) and a nice multi disc converter.
11 second car under stock hood.
bulldog is offline
post #9 of 12 (permalink) Old 12-11-2013, 05:39 PM
while this suggestion does have some merit, when someone says "I don't have the bucks I used to...", I generally take that as "I don't have thousands and thousands of dollars to dump into this thing". Unless we get a clear answer of how much $$$ is available, even the simplest response may not hold any value.
So how much are we talking about here, exactly?
post #10 of 12 (permalink) Old 12-11-2013, 08:20 PM
Mgino96tbird46's Avatar
3800-4000 stall torque converter, 3.73 gears, and a tune. Bam! Low 13's to high 12's.
Mgino96tbird46 is offline
post #11 of 12 (permalink) Old 12-11-2013, 09:26 PM
MA Drag Race Team Coordinator
1MTNCAT's Avatar
HMMM, Tell that to the Lincoln boys. No way, NA!!!
Steve
Nitrous 11.75 @ 114 MPH
1MTNCAT is offline
post #12 of 12 (permalink) Old 12-13-2013, 11:00 AM
95_SilverBird's Avatar
Drive ability will be just fine. I have 4000 stall and 4.10's in the bird. I drive it almost daily and love it. Don't forget a big tranny cooler.
Eibach 1.5" Lower Springs, Koni Adjustable Shocks, SCP IRS Brace, SCP Lower Engine Cradle Brace, Mark VIII LCAs
Chuck's Poly Motor Mounts, 13" PBR Front and Cobra rear brakes, 245-45-18 ADR Kasai Wheels, RichardM Intake Tube
Super Coupe leather seats and console, Pioneer Head, Audison Amps, Boston SL Components, 10" Boston G5 subs, Reverse Glow EL Gauges, Super Coupe Ground Effects, '96 Hood and Headlights, Custom paint: Tungsten Silver, PI Intake, 4000 stall
95_SilverBird is offline
