Details please - TCCoA Forums
post #1 of 10 (permalink) Old 12-14-2013, 07:03 PM Thread Starter
r429460's Avatar
Details please
Is it a simple task to swap the electronics,
In order to creat a V8 car from a v6?
Obviously a Mod Motor.
Quickest N/A Modular MN12.
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #2 of 10 (permalink) Old 12-14-2013, 08:17 PM
ricklovin93's Avatar
you would need the entire engine harness and ecm/pcm from a V8 car, best bet would be to buy a V8 parts car and just swap everything.
"A well regulated militia, being necessary to the security of a free state, the right of the people to keep and bear arms, shall not be infringed"
ricklovin93 is offline
post #3 of 10 (permalink) Old 12-14-2013, 09:45 PM
94/5 or 96/7?
96/7 is the easier of the two since you only need to swap the engine harness and PCM. On 94/5s you need to swap the engine harness, the PCM and the PCM harness as well. Make sure whatever year the car is the doner is the same, 96/7 harnesses don't interchange with 94/5s and vice versa.
post #4 of 10 (permalink) Old 12-15-2013, 11:29 AM
nall_one's Avatar
with a little cutting and splicing you can make them work :P but then you have the TCC solenoid to worry about.
nall_one is offline
post #5 of 10 (permalink) Old 12-15-2013, 10:18 PM
don't the transmission get moved in the v-8 car I did read on hear the driveshaft are different length from v-6 to a v-8
transtech520 is offline
post #6 of 10 (permalink) Old 12-15-2013, 10:30 PM
nall_one's Avatar
their is a small difference in the shaft. not sure the trans actually moved much if at all though.
http://forums.tccoa.com/showthread.php?t=102567
looks like an inch diff give or take
nall_one is offline
post #7 of 10 (permalink) Old 12-16-2013, 08:38 AM Thread Starter
r429460's Avatar
Without the knowledge, and without the desire to do all that swapping,
I'll just get a V8 car.
V6 cars here are $500-$600.
V8 cars are $1000-$1500.
Thanke for the information guys.
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #8 of 10 (permalink) Old 12-16-2013, 10:37 AM
The only way I would consider doing it is if you found a V6 car for under $1000 that was absolutely perfect in every way in terms of body, paint, and interior. Other than that, it isn't worth the time and effort involved when a V8 car can be bought for $500-1000 more in similar shape.
MadMikeyL is online now
post #9 of 10 (permalink) Old 12-16-2013, 04:27 PM
I agree; I'd charge more than $500 to swap the wiring...
post #10 of 10 (permalink) Old 12-16-2013, 07:31 PM
wow 500.00 to 600.00 for a v-6 car.....I paid 50.00 for mine :-)
