A/C Delete - TCCoA Forums
post #1 of 17 (permalink) Old 02-09-2014, 12:44 PM Thread Starter
ROLLINTHUNDER's Avatar
A/C Delete
I may shock GM a little with this one!lol. Couldnt find it searching but has anyone done a compressor delete on these motors? Mine doesnt work and im just wanting to take it all off. We sell a bypass pulley here at work for it but I would rather not put anything back on there. Seems I would have belt tensioner and idler pully issues to figure out the routing. Thanks!
Eibach pro kit springs w/rear cobra bilstiens, rear disc conversion, 2000 Cobra R wheels, 89 SC track-lock swap w/mark 8 cv shafts, 89 front and rear sway bars
ROLLINTHUNDER is offline
post #2 of 17 (permalink) Old 02-09-2014, 02:43 PM
I've got the Ford Racing one on mine. Pulley is the same size so you keep the same belt and routing. Only cost like $30, not much more than a new Gatorback
post #3 of 17 (permalink) Old 02-09-2014, 02:46 PM Thread Starter
Yeah thats what it was 30 dollars. It would be tricky figuring out how to do it without the bypass pulley.
post #4 of 17 (permalink) Old 02-09-2014, 04:32 PM
Yeah that's why I bought mine. Had I needed a new belt, maybe I'd have looked into bypassing but the delete bracket was ultimately nearly the same cost as the shorter belt and I wouldn't have to do any measuring to determine the size I'd need.
post #5 of 17 (permalink) Old 02-09-2014, 05:02 PM
Running the delete pulley on mine as well.
post #6 of 17 (permalink) Old 02-09-2014, 08:32 PM Thread Starter
That looks good right there! Tryin to clean my engine bay up a bit. Too much goin on with that dohc crowdin everything up. Prolly noy much but can anyone think of some things that just doesn't HAVE to be there?
post #7 of 17 (permalink) Old 02-10-2014, 12:52 AM
Boost!!!
modularbird's Avatar
Anyone know where I can get one for a 4.6 8 rib setup?
Blake
1996 thunderbird lx (the silver slut)
http://forums.tccoa.com/vbpicgallery.php?do=view&g=387
modularbird is offline
post #8 of 17 (permalink) Old 02-10-2014, 01:04 AM
A F or E series without A/C would be the first place I'd look. I don't think ford racing sells them though, you might have to go through the regular parts counter.
post #9 of 17 (permalink) Old 02-10-2014, 09:02 AM Thread Starter
Im an assistant manager at Advance Auto and can check for you when i go back to work wednesday. You may have to do a pully swap onto the bracket that fits your car if anything. If theres anything you guys need me to check on for you just let me know.
post #10 of 17 (permalink) Old 02-10-2014, 12:38 PM
S4gunn's Avatar
Rockauto.com carries A/C bypass pulleys. I checked and the one they spec for your car is
DORMAN Part # 34191
http://goo.gl/csaet4
S4gunn is offline
post #11 of 17 (permalink) Old 02-10-2014, 04:32 PM
DORMAN Part # 34191
That's a 6-rib. He's looking for a 8-rib.
post #12 of 17 (permalink) Old 02-10-2014, 04:38 PM
I think it might be 34189, that's for a 5.4 E250 which I'm pretty sure is 8 rib
post #13 of 17 (permalink) Old 02-10-2014, 09:11 PM
Boost!!!
I'm just not sure which one to get because all the ones for the standard 4.6 are 6 rib and I don't want to buy a bunch of parts that "might" fit...lol
Blake
post #14 of 17 (permalink) Old 02-10-2014, 09:12 PM
According to Summit, it's 8 rib: http://www.summitracing.com/parts/rn...FepFMgodLQMA4g
post #15 of 17 (permalink) Old 02-10-2014, 09:18 PM
If there wasn't several feet of snow on top of the usual several feet of mud at the junkyards I'd go and pull or at least verify it being 8 rib on a E series work van for ya. 34189 is for sure meant for an 8 rib E series, so unless rockauto has it listed wrong I'd be fairly certain it's what you need
post #16 of 17 (permalink) Old 02-10-2014, 09:26 PM
My 1997 F-150 with the 4.6 has the 8-rib configuration. The listed Dorman Delete Pulley for it is Part Number : 34188. Hope this helps avoid any confusion. I don't see why it wouldn't work in your application.
post #17 of 17 (permalink) Old 02-10-2014, 09:45 PM
Boost!!!
sweet! Thanks guys. The slut is going to be back together completely (and hopefully retuned) by the end of next month. Haven't driven her the way I want to in about 6 months. I'm so ready.
Blake
