Vibration Damper - TCCoA Forums
post #1 of 15 (permalink) Old 02-28-2014, 09:30 PM Thread Starter
Vibration Damper
Can anyone tell me how important the vibration damper that is attached the the transmission near the transmission mount on a 97 T-bird 4.6 automatic is? I had a new aftermarker catalytic converter (Walker PN 50516) and it would not clear it. The shop removed it so they could get the cat to fit.
vairlady is offline
post #2 of 15 (permalink) Old 02-28-2014, 10:01 PM
did the shop show you the part they removed? Maybe I've just been out of the mechanics game for too long but I can't see why they'd need to remove anything to fit the walker catted y pipe assembly
blue95lx is offline
post #3 of 15 (permalink) Old 02-28-2014, 10:09 PM
96dirtybird's Avatar
I agree with blue, I had the full Y Magnaflow aftermarket assembly put in, not too long ago. Zero clearance issues.
96dirtybird is offline
post #4 of 15 (permalink) Old 02-28-2014, 10:15 PM
S4gunn's Avatar
If this is the same vibration damper referenced in this article, it dampens driveshaft harmonics and you'll want to keep it.
See halfway down in the paragraph starting with "One Side Note"
http://tccoa.com/articles/tranny/tra...n/page17.shtml
-g
http://goo.gl/csaet4
S4gunn is offline
post #5 of 15 (permalink) Old 03-01-2014, 08:49 AM
ha ha.....moose balls..
04 mustang pi engine, 4R75W, 2500 stall TC, Teksid block still in the garage being dreamed about
AlanE is offline
post #6 of 15 (permalink) Old 03-01-2014, 01:47 PM Thread Starter
I have the part. It's about the size of a beer can and sounds like it had buck shot inside.
vairlady is offline
post #7 of 15 (permalink) Old 03-01-2014, 04:48 PM
97 30th's Avatar
The one in the article is the weight attached to the pinion of the solid axle 8.8's not the one on the trans. Mike
You can't fix stupid
97 30th is offline
post #8 of 15 (permalink) Old 03-01-2014, 05:34 PM
1995 cougar xr7's Avatar
What part are you talking about ? I can t open the page . I changed out my tranny and redid my whole exhaust and have no idea what you're talking about
1995 cougar xr7 is offline
post #9 of 15 (permalink) Old 03-01-2014, 07:36 PM
It's a vibration damper, like you said. And yes, it is full of lead shot,IIRC.
It was probably in the rearmost holes, like mine was, and go in the way.
I had a similar problem, and yes, it does need to be there.
It should fit in the most forward set of holes.
I'd use it if I could.
Grog6 is online now
post #10 of 15 (permalink) Old 03-02-2014, 12:41 PM
Rayo's Avatar
Axle Shaft Damper
Here's a diagram pic of what I think the OP is talking about..
Does anyone have an actual pic of one of these??
1991 Ford Thunderbird Sport
Rayo is offline
post #11 of 15 (permalink) Old 03-02-2014, 03:57 PM
Only 96/7s had them, it's not necessary.
post #12 of 15 (permalink) Old 03-02-2014, 09:55 PM
Mgino96tbird46's Avatar
RobertP removed mine when we did the J-mod. I couldn't tell a difference. The transmission has 168,000 hard driven miles on it, still buttery smooth.
Mgino96tbird46 is offline
post #13 of 15 (permalink) Old 03-02-2014, 10:05 PM
Agreed. Removing that really isn't a big deal.
post #14 of 15 (permalink) Old 03-03-2014, 08:44 AM
I removed mine a long time ago, HOWEVER
I have had the tail shaft housing loosen up three different times on two different transmissions, so there may be some usefulness to the weight.
~Rick
TCCoA Sig
post #15 of 15 (permalink) Old 03-14-2014, 10:23 PM Thread Starter
Smile Vibration damper
Thanks for all your replies. The picture is very helpful, I will have to see if mine has the extra holes and if it will work.
vairlady is offline
