any ideas? - TCCoA Forums
post #1 of 4 (permalink) Old 04-22-2014, 08:58 AM Thread Starter
any ideas?
95 xr7 4.6 runs fine, doggy off line, no codes, avg 20mpg. unplug maf, runs perfect, spins tires off the line, code p0102, (maf), avg 22 mpg + ck eng light on, and every once in a while it will stumble on soft take off ? ideas?
95 4.6 100% stock ( 4 now)
jercr77 is offline
post #2 of 4 (permalink) Old 04-22-2014, 09:07 AM
Originally Posted by jercr77 View Post
unplug maf, runs perfect [...] code p0102, (maf)
I think you answered your own question. Replace the MAF sensor.
post #3 of 4 (permalink) Old 04-22-2014, 10:19 AM
96PRLBRD's Avatar
Sounds like a MAF (or wiring) problem http://www.obd-codes.com/p0102
--> My most recent pics <--
96PRLBRD is offline
post #4 of 4 (permalink) Old 04-22-2014, 04:05 PM
sousa632's Avatar
Have you cleaned the MAF lately? Otherwise you should start looking for a replacement.
John
1996 TBird LX 4.6
2001 Sable Wagon 3.0 Duratec
sousa632 is offline
