Broke 8mm bolt holding camshaft position sensor in place - TCCoA Forums
post #1 of 24 (permalink) Old 05-08-2014, 03:21 PM Thread Starter
Well it is what title said. Any solutions to this joyous problem? Was taking sensor out when all went loose and i brought wrench down with head of bolt on it. I seem to have this problem pretty often. Snapped all bolts holding exhaust on but that wasnt too bad a problem as i just took my torch and blew holes out and popped some new bolts in. Is that my only viable option here with the terrible position it is in?
Unzem is offline
post #2 of 24 (permalink) Old 05-08-2014, 03:23 PM
EZ-out bit.
post #3 of 24 (permalink) Old 05-08-2014, 05:37 PM Thread Starter
That was my first thought but no possible way i can get a drill in there or even my dremel to drill or extract it out.
Unzem is offline
post #4 of 24 (permalink) Old 05-08-2014, 06:33 PM
You're f'ed.
You can buy or borrow a right angle drill to drill it out, or JB weld it in place, and be constantly stranded somewhere until you dink with it.
I'd drill it out, personally.
If you're breaking off bolts on a Texas car, I'd worry about my technique; Pittsburg PA has salt issues, but Texas can't be worse than here...
post #5 of 24 (permalink) Old 05-08-2014, 06:48 PM
driller's Avatar
You should be able to get a right angle drill and short bit(s). I've been in a similar predicament and went out and bought a DeWalt right angle drill.
driller is offline
post #6 of 24 (permalink) Old 05-08-2014, 06:52 PM Thread Starter
Guess im f'ed because my right angle drill attachment cant get in there either. Was thinking about putting a heavy duty hose clamp to hold itin there. Has the perfect tab sticking out if that would work. We have really high humidity here and being parked in my pasture doesnt help either, not sure its my technique because it didnt take much and it snapped off.
Unzem is offline
post #7 of 24 (permalink) Old 05-08-2014, 06:53 PM
Get the coil/ps reservoir bracket out of the way. It isn't that difficult to get to this bolt.
You'd be surprised. A rig just arrived at work the other day that looked like it had spent the last fifty years here in the rust belt. Turns out it had only seen fifteen years of duty in Corpus Christi, TX. The salt in the air from the gulf absolutely decimated it. That being said, Pittsburg, TX, is a good 250+ miles from the gulf.
post #8 of 24 (permalink) Old 05-08-2014, 06:56 PM Thread Starter
My other option i was thinking about is taking a stud ans tacking it on there and just thread a nut onto that. Would probably work better but be a pita sticking a rod down in there to do it with
Unzem is offline
post #9 of 24 (permalink) Old 05-08-2014, 06:59 PM
Did the bolt break off in the hole, or is any of it sticking proud of the timing cover?
post #10 of 24 (permalink) Old 05-08-2014, 07:01 PM Thread Starter
I have coil packs off. It broke almost flush with it. Tiny bit sticking out but not much
http://imgur.com/b2M1S5g
http://imgur.com/gmN9k1Z
Unzem is offline
post #11 of 24 (permalink) Old 05-08-2014, 07:07 PM
That's the crank sensor not cam sensor makes more sense.
post #12 of 24 (permalink) Old 05-08-2014, 07:10 PM Thread Starter
Crank is behind power steering reservoir i thought. Nevermind got confused after looking again. Either way i have a broken bolt off in there...
Unzem is offline
post #13 of 24 (permalink) Old 05-08-2014, 07:32 PM
Time to remove the timing cover.
post #14 of 24 (permalink) Old 05-08-2014, 07:53 PM Thread Starter
Think i will try tacking a small threaded stud onto bolt stuck in there first then just use a nut that threads onto it first. If not hooking this pos up to my tractor and yanking it into my pasture for some rock climbing practice like the way my old altima went with my four wheeler lol. Too many other vehichles at my house to have this thing taking up space in shop or under carport. Need to get headers and exhaust put on my Z.
Unzem is offline
post #15 of 24 (permalink) Old 05-08-2014, 09:37 PM
I forget about saltwater; it eats anything.
I was able to wrench out the exhaust bolts on both engines I've done here...
IIRC, the cam sensor is bolted into the front cover; Worst case, you can yank that in the car, then work on it on the bench.
post #16 of 24 (permalink) Old 05-09-2014, 06:01 AM
So are we talking about the crank or cam sensor now? The cam sensor is behind the coil pack/ps reservoir bracket, the crank sensor is behind the AC compressor. Both are on the front timing cover.
If the bolt is sticking proud of the timing cover surface, you may be able to tack a nut to it and back it out. If all else fails, you can always just replace the timing cover.
post #17 of 24 (permalink) Old 05-09-2014, 08:16 AM
Mgino96tbird46's Avatar
I'd pull the timing cover off and try to get the bolt out. That way it is a lot easier to work with instead of trying to do it in that cramped space. No reason to replace the timing cover if the rest of the bolt can be extracted.
Mgino96tbird46 is offline
post #18 of 24 (permalink) Old 05-09-2014, 12:52 PM Thread Starter
http://imgur.com/8KC56sW
Here is my fix I decided this was the easiest way to start with. Its on there tight as a drum and still cranks up so I guess this will work until I ever decide to take timing cover off.
Unzem is offline
post #19 of 24 (permalink) Old 05-09-2014, 01:19 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
Lol that's awesome. Way to use that Texas ingenuity! Yes that is the crankshaft position sensor (ckp)
-Rob
Rob is offline
post #20 of 24 (permalink) Old 05-09-2014, 01:59 PM Thread Starter
Haha thanks, replaced both crank and cam sensor hoping that might fix my other problems im having in my other thread but sadly not the case. Guess I get to do hours and hours of more searching while waiting on ecm to arrive. Thanks for the help guys.
Unzem is offline
post #21 of 24 (permalink) Old 05-09-2014, 03:21 PM
I would have pulled the cover before attempting a hillbilly repair like that. I have more integrity than that. Then again I do this for a living.
post #22 of 24 (permalink) Old 05-09-2014, 03:55 PM Thread Starter
If this was my daily and I didnt have 5 other vehicles I could drive I would have done it correct. I gave $600 for this car and got my moniea worth it out of it. This is a car I tear ruts up with in my pasture, not making long road trips in it lol.
Unzem is offline
post #23 of 24 (permalink) Old 05-09-2014, 07:05 PM
nall_one's Avatar
what a sad life for an old bird. i would certainly hate to see any video evidence of her being run over with a 4x4 >.>
i suppose its no worse then most of the ones i still see driving around here in the salt without any lower rocker panels, quarters or fenders left.or half the parts and pieces duct taped on. i looked inside an old rusty cougar a couple days back that had more crap inside then the back of a garbage truck.
let her die with dignity so somebody can have the parts :P
nall_one is offline
post #24 of 24 (permalink) Old 05-12-2014, 06:07 PM
Rob
Rob's Avatar
Let us know what your other problems are and if the PCM cures them. I have a strange issue that I replaced the PCM for last year.
It would usually idle low and either stall or just cut out heavily and flicker, not flash, the mil. I caught it doing this while idling and had my scanner on it. I did a cylinder contribution test ( essentially a misfire monitor) and noticed 1 and 3 were missing at the same time at low rpms. I wiggled the harness all around the front of the intake and it cleared up and has been trouble free for a week now. Close inspection of the wrapped harness did t yield any results. I may need remove the wrap and check the wires closely. I suspect a wire was shorting intermittently and drawing too much current from the PCM. I was also a little suspicious of my screamin demon coils maybe being too much of a load on the PCM, but I think it's fine.
5-16-14 problem came back earlier
-Rob
Rob is offline
