Random stutter. - TCCoA Forums
post #1 of 35 (permalink) Old 06-08-2014, 11:26 AM Thread Starter
Random stutter.
I've been trying to figure this out for weeks, but I just can't get a hold of it. Maybe someone here can help me. I try to put things here in chronological order, but there's a high chance I'll be missing something. Have to add those later. Here goes.
Symptoms:
-Random but continuous stuttering on cruising RPM. If I pay attention I can see the tacho needle twitch slightly. More strongly present when the ambient temp is below ~20 C (~68 F) but gone when the engine is cold.
-MAF gives very odd readings. Only on idle the value stays reasonable, about 5...8 g/s. On cruising RPM the value jumps up and down from below idle values to way over hundred g/s.
-LTFT is +99.2% on both banks. STFT seems to be normal.
-Also O2 sensors signal voltages jump wildly through the whole scale of 0.1 to 0.9 and some times over that. I've seen readings of 0 and 0.95 and I think they shouldn't do that (except 0 on WOT).
-Also IAT sensor occasionally gives false readings. Or so it seems. Maybe the heat from the engine affects more than I think.
-No DTC. Not even a pending one.
Done so far:
-Replaced the MAF sensor. Old one gave me about 90 mV signal on idle and not much more when revving slightly. Also the throttle response is back to normal with the new MAF sensor. It's a Delphi AF10113. Any experiences on these sensors?
-Replaced spark plugs and wires.
-Tested the EGR valve. Seems to be working and gave the DTC of high EGR flow.
-Tried to locate an air leak, visually and with an starting aid spray. Replaced some deteriorated vacuum hoses on the EVAP system.
-Today I plugged the EVAP at the PCV valve. Still stuttering.
Any ideas what to try next?
Shalafi is offline
post #2 of 35 (permalink) Old 06-08-2014, 01:32 PM
Datalog the EEC voltage, and see if it's erratic as well.
You probably have a bad ground wire, probably at the end by the starter.
These are old enough that the cable may be partially rotten, and have green dust coming out of it; that's a sign you need to replace it.
This is the second one this week; there could be a run of these problems...
Grog6 is online now
post #3 of 35 (permalink) Old 06-08-2014, 02:28 PM Thread Starter
Too bad this Torque App (on android) doesn't give me that EEC voltage. Need to see if multimeter is of any use on this.
I'm not sure did I get this right. You mean that sensors and / or EEC use the same ground cable as the starter? Or, this ground cable is somewhere near the starter? I'll see what I can find around there anyway.
Shalafi is offline
post #4 of 35 (permalink) Old 06-08-2014, 05:37 PM
Moderator & Teksid Whore
guitar maestro's Avatar
most voltmeters won't show millisecond voltage dips, which is why datalogging is invaluable. Any weird spikes in any datalogged parameter usually means you have an electrical gremlin.
guitar maestro is offline
post #5 of 35 (permalink) Old 06-12-2014, 02:26 PM Thread Starter
Haven't got much time for this, but.. So far only corroded (that green dust) cable I found is by the battery. A Y-shaped cable; one end to the battery negative, one end to the chassis (to a fender mounting screw) an one to a 4-pole connector and onwards to somewhere.. deep. Can anyone tell me what this cable is, which equipment does it ground, and can it cause this problem?
About that datalogging. A datalogger is something more than a simple (cheap) OBD II reader, right?
Shalafi is offline
post #6 of 35 (permalink) Old 06-12-2014, 07:44 PM
Don't worry about what "it" grounds. Trace it and replace it. It will alleviate future problems if you plan to keep the car. Copper corrosion doesn't stop just because you want it to or because you can't see where the wire leads/terminates at.
As for datalogging, it usually involves saving scanned data to view on a computer. Obviously you can take care of things without one as many do, it will just be more time consuming and $$$ consuming.
post #7 of 35 (permalink) Old 06-13-2014, 03:50 AM Thread Starter
Well, yes, it needs to be replaced. I asked 'cause I'd like to know what are the chances for this cable being the culprit, or should I be searching some other damaged parts too. Knowing what these four particular ground leads are used for might help me understand this and the electrical systems of this car in general.
I miss the days when fingers and toes were enough to count the wires in the engine room..
Shalafi is offline
post #8 of 35 (permalink) Old 06-26-2014, 09:47 AM Thread Starter
Update.
I did an emergency repair for that Y-cable I mentioned earlier. It may not be the best of its kind but it should do the job. But this repair did nothing to the problem. There's still that thick ground cable to the engine block. It looks fine to me, but I'll replace that too, later. Oil filter needs to be removed to reach the cable end, so this must wait to the next oil change. Which is soon.
Also, I measured resistances from the block and a couple of grounding points to the battery negative. They all showed 0 to 0.2 Ohms. Does this sound right? I never thought the resistance can go to zero in these cases.. Have to look to it again. There must be more grounding points than those two right behind the headlights. But where? I know two are under the kickpanels in the cabin.
Owner's manual says that there is a relay for EEC in the distribution box, but there isn't. Just an emply slot, not even wired. Can some one explain this?
Battery voltage was 12.25 V at rest. I hoped to see more, but on the other hand the car starts fine every morning. But then again I saw this thread. The battery isn't very old, replaced 04/2011 if the markings are to be trusted. The alternator is replaced at the same time, I believe. It was shining new when I bought the car 11/2012.
And here is something about bad IAC valve and/or O2 sensors.
Comments and suggestions, please?
Shalafi is offline
post #9 of 35 (permalink) Old 06-27-2014, 06:13 AM
it takes time to go threw the grounds it is frustrating when doing but in the end it pays off.
what is wrong with the iac and the 02?
is it throwing codes or is it stalling when you first start up?
95mercxr7 is offline
post #10 of 35 (permalink) Old 06-27-2014, 06:54 AM Thread Starter
Hopefully nothing with the IAC or O2 sensors. It was just one suggestion in a case with similar symptoms. Check the link, if You didn't already.
No codes after I replaced the MAF sensor. Not even a pending one. (Except of course the one initiated by a EGR valve test and erased immediately.)
edit: It has stalled once with no obvious reason, but started normally right after.
Shalafi is offline
post #11 of 35 (permalink) Old 06-27-2014, 11:45 AM
I'm interested in which scanner you are using. Mainly to decipher the LTFT readings. Different scanners give different numbers for the same LTFT/STFTs.
What do the STFTs show right when you start up the car when it's cold? Then how do these numbers change as the car warms up in the following minute? How does this number change when it gets to stuttering?
What do the LTFTs show right when you start up the car when it's cold? Then how do these numbers change as the car warms up in the following minute? How does this number change when it gets to stuttuering?
post #12 of 35 (permalink) Old 06-30-2014, 09:46 AM Thread Starter
It's an application for Android, called Torque. Here's a link. My phone is Motorola Droid 4, if that makes any difference. And of course some generic bluetooth transmitter in the OBD II connector. I know it's no way a professional setup, but it's the best (and only) I have at hand right now.
I've never paid that much attention to it, but I have something.. STFT was +46% when starting up cold this morning as the ambient temp was 12 °C (53 °F). Immediately it begun to decrease steadily to about +10% and then I hit the road. While driving the STFT was low for most of the time, -10..-20%. Occasionally it roamed around zero and when accelerating it increased to about +20%. This is the part that needs more testing, but I believe the symptoms appear when the STFT goes low.
Well this is much easier LTFT in +99.2% on both banks all the time. No matter what I do, when I do it, or under what conditions I do it. Also, when KOEO the STFT says "No Data" and LTFT the same +99.2%.
I observed the O2 sensor signal voltages too. At cold start all say 0.1 V. Very soon pre-cat sensors voltages increase quite steadily to 0.9. Post-cat sensors stay at 0.1 V much longer, for the first mile or so. At some point all the O2 voltages start to jump up and down pretty wildly and this is the point when the first stutters appear.
Shalafi is offline
post #13 of 35 (permalink) Old 06-30-2014, 10:54 AM
Without knowing in which direction the percentage swings indicate lean or rich, that STFT data is useless. The only thing it tells you is that the air:fuel ratio is not what it should be (which would be 0%). It's one or the other (lean or rich), but which one? Do some research as to which sides (positive or neg. %) mean what, and we might get in the ballpark.
Edit: Nevermind. The torque forums show that a lot of users show the LTFT locked at 99.2, which is what you're showing. That's not right. If you can't trust the LTFT, then you probably can't trust the STFT either.
My gut feeling is that you are experiencing injector(s) being hung open by the EEC, vacuum leak you haven't found yet, or fuel pressure regulator fault.
post #14 of 35 (permalink) Old 07-02-2014, 09:25 AM Thread Starter
How silly of me not looking for Torque forums.. So the LTFT readings are useless. The next thoughts are based on my limited knowledge on fuel injected engines in general and this gut feeling guitar maestro has. Please correct me if.. umm.. when I've missunderstood something.
Let's assume, for a moment, that STFT readings would at least give us a hint of what's going on. A cold engine needs rich mixture to start up and run the first moments. Also, on (near?) WOT EEC orders an extra load of fuel on top of the base dose (and ignores O2 signals). In both cases Torque app shows positive values for STFT, so I presume pos. values means more and neg. values less fuel compared to the base dose. Symptoms appear when STFT readings go low, let's say -10%. Why would it go that low? Is EEC trying to fix overly rich mixture detected by the O2 sensors? If yes, why is the mixture rich?
An injector malfunction: One injector would make trouble on one bank but both STFT readings go very nicely hand-in-hand. Not equal values, but close. Two injectors, one on each bank, failing would be hazardous, I guess.
High fuel pressure: That would affect on both banks equally, just like the situation seems to be. So, fuel pressure reg. fault or clogged fuel return line? I sure hope it's the first one.
Makes sense? Yes? No?
Anyway, I put in an order for a new fuel pressure regulator. Should be at hand on Friday. I hope this works..
Shalafi is offline
post #15 of 35 (permalink) Old 07-02-2014, 11:02 AM
Why didn't you just test the fuel pressure beforehand?
As for fueling, the fuel delivery model in the PCM is complicated, and there are too many assumptions. One thing I learned in Logic class, is that once even only one statement is false, any conclusion can be deduced from the original premise. One has to be careful when trying to figure things out when intermediate steps cannot be verified. But generally speaking, the only times the mixture should be commanded rich is: start-up, and when engine load goes over a certain amount while in Open Loop status. At start up the fueling is from pre-set tables in the PCM, ECT value, and an internal timer in the PCM. At higher engine loads (depending largely on whether or not the PCM has detected the Open Loop Flag =1), rich mixtures are commanded from a pre-set table but rely on input from the maf sensor and RPM (holding all other things constant). For PCMs of our cars, when near/at WOT, the STFTs stop reporting fueling corrections (trims), and start reporting commanded lambda. But on most dataloggers, this deviation from stoichiometric fueling is based off of the number "1.00" representing a 14.67:1 air fuel ratio. Lower than 1 is richer, higher than 1 is leaner. The problem is this: TOTAL fueling is not determined by the STFTs correction alone. It is a joint venture between the STFTs (even if it is in OL already) and whatever correction the LTFTs have already stored in their tables. So as you can see, having the LTFTs locked/useless makes trying to deduce anything useless (remember the bit about logic from above), for you cannot determine actual rich/lean fueling (without a wideband O2 sensor) if you don't have real access to both fuel trims.
post #16 of 35 (permalink) Old 07-02-2014, 11:47 AM Thread Starter
I asked around for a fuel pressure gauge to borrow, but none was available. At least no one reported back this quick. Found a gauge set in a nearby store but it costs more than four times the fuel pressure regulator. Now as I think about it, one chance is to go to a hydraulics store and compile an applicable gauge..
I do realize that there is too many assumptions to call it logic in any way. But it didn't cross my mind the fueling could be that complicated..
Oh well, I wait for the new FPR to arrive and get back to this when it's installed and tested on road.
Shalafi is offline
post #17 of 35 (permalink) Old 07-07-2014, 02:26 AM
bluecar5556's Avatar
It sounds like an ignition issue, perhaps the ignition coil packs?
Edit:
Check for misfire DTC's
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look ignorant.
When you do NOT ask questions, you will STAY ignorant.
1997 Mercury Cougar XR7; 4.6L, 4R70W
1997 Cougar XR7 4.6L "bone stock"
bluecar5556 is offline
post #18 of 35 (permalink) Old 07-07-2014, 08:15 AM Thread Starter
Replaced the FPR today. The symptoms are now gone, but I'm not very optimistic for it. That stuttering is been vanishing before, when the ambient temp is high. And it's a very hot day here.
Edit:
Been thinking about the coil packs too, but there's no DTC to be checked.
That MAF sensor still bothers me. Maybe I wasn't clear enought in the first message, but the new sensor seems to be acting up too. (The old one was dead, that's for sure.) This new sensor gives reasonable values in two occasions only: A few minutes after cold start and when accelerating hard enought. WOT isn't necessary, but 1/2...2/3 throttle does it. Rest of the time it's reading is lagging somewhere around idle values or a little higher and making sudden jumps, sometimes even higher than it's possible in the current conditions.
Shalafi is offline
post #19 of 35 (permalink) Old 07-07-2014, 10:58 AM
Or it could just be that data logging app that is not reporting correct maf voltage.
post #20 of 35 (permalink) Old 07-07-2014, 12:06 PM Thread Starter
It could be..
I'll check the MAF signal voltage with a multimeter while driving some day. It should be possible with a wire from the MAF signal to the cabin and a good grounding point.
On idle the signal voltage is good, a little less than 1 V. And so is the MAF reading in Torque app, 5..8 g/s and not jumping like it does when driving.
Shalafi is offline
post #21 of 35 (permalink) Old 07-21-2014, 11:40 AM Thread Starter
Today I had the time to do the test I mentioned in the previous message. MAF sensor - considering throttle pos. and RPM at any given time - gives reasonable signal voltages. So this MAF sensor seems to be good.
Was still thinking about that Torque app.. Smart phone apps aren't really my field of specialty, but I believe this Torque is just a dumb repeater. It shows me what it gets from the BT transmitter, which again sends what it gets from the OBD II. The values Torque shows, even when stable, may not be right but at least they should act normaly considering the conditions.
So, what happens in the EEC in those two occasions I wrote about earlier (cold start and acceleration) when MAF value acts reasonable? And what changes during rest of the time, meaning cruising mainly, when MAF value acts like a grumpy teenager? Or, long mind flooding short, what are the chances my EEC is bad?
I think I must give up and take the car to a shop with decent diagnostic tools..
Shalafi is offline
post #22 of 35 (permalink) Old 07-21-2014, 12:15 PM
"what happens" is a very broad, vague question.
post #23 of 35 (permalink) Old 07-21-2014, 04:25 PM
Have you checked the plugs?
Maybe they were the wrong plating; anything other than double platinum wears the center pin off four of them...
Also check for water on the spark plug boots.
Grog6 is online now
post #24 of 35 (permalink) Old 07-28-2014, 12:59 PM Thread Starter
Spark plugs were the first thing I replaced (after that MAF sensor). I can't remember which brand or type they were, but nothing special. Nippon Denso maybe. Old ones looked really bad, but new plugs didn't change a thing. There was no water on the boots.
You mean these plugs? You think it'd be worth a try?
Shalafi is offline
post #25 of 35 (permalink) Old 07-28-2014, 06:39 PM
... You think it'd be worth a try?
Those wear fast too. Our ignitions put out some heat.
The best wearing plug I've found is ACDelco's double platinum; It's not as thin as others, and is cheaper and almost identical to the MC OEM part.
A copper plug is preferred for race engines; but race plugs get looked at regularly; it's a commitment.
If you forget...
On the street they need to be dressed every 10k mi. They will start missing by ~13k. (ymmv)
Most people I know that run coppers swap them with other plugs every other month, then clean and dress the yanked ones with a fine file, and Add them to the rotation, lol.
Grog6 is online now
post #26 of 35 (permalink) Old 07-29-2014, 09:00 AM Thread Starter
OK, so "basic" plugs should work, for a while. And those are still nearly new. I don't think that's the problem now, but thanks anyway. I keep your tip in mind when it's time renew the plugs.
But how about the O2 sensors? Just thinking, again. Symptoms are gone 1) at cold start and the very first minutes after that and 2) at (near) WOT conditions. In both cases EEC goes Open Loop, right?
Shalafi is offline
post #27 of 35 (permalink) Old 07-31-2014, 09:15 AM Thread Starter
About that data logging. I thought I might invest some to it. What kind of setups do You guys use or would recommend? I looked up some stuff about it, but it really doesn't say much to me. There is one "Ford only" link and software. FORmiDable + F Super. I suppose that is not the only choice, but what would be the benefits with this?
Shalafi is offline
post #28 of 35 (permalink) Old 07-31-2014, 09:35 AM
the best way is to use SCT's LiveLink software (free) with a handheld programmer (flasher) like an Xcal2 or Xcal3. You can usually find some on ebay that are locked to other vehicles for programming purposes, but the datalogging can still be used on any ford vehicle OBD-II. You use your PC to set it all up (which parameters to log), and then you can either log using the device only, or in conjunction with a laptop in the car for logging extended periods of time. There is a write-up in the EEC tuning forum about this.
post #29 of 35 (permalink) Old 08-18-2014, 09:56 AM Thread Starter
Umm, yeah. That flasher would be very tempting, or maybe a must have, if I was to reprogram the PCM. Maybe some day I will, but not now. And for data logging only I think it's a bit high priced after shipping, VAT and maybe customs.
I was thinking something like this, for example. (Sorry, Finnish only.) It comes bundled with moDiag software. Here's a link.
Shalafi is offline
post #30 of 35 (permalink) Old 08-20-2014, 10:23 PM
I know this might seem stupid to suggest but have you tried to simply swap to mercon v tranmission fluid?
reason I ask is when i first got my tbird from my grandfather he had lots of miles on it and it wasn't driven (just started up 10 minutes a day) for over 2 years and randomly i'd get this strange studder around 1400-1800 rpm (cruising rpm in the area i live). after a full tune up, new exhaust, new u joints, this that and everything else i joined this site and read up on torque convertor shutter. read i could use mercon v fluid instead of dex/merc.
drained the trans and torque converter the next day, refilled with mercon v and shudder gone. i could be way off but after spending lots of money trying to get the car to run right and 100 bucks and a couple of hours in my garage fixing the problem figured id chime in. worth a look.
blue95lx is offline
