swap in progress sensor question - TCCoA Forums
post #1 of 7 (permalink) Old 04-28-2016, 05:24 PM Thread Starter
Dustytheredneck's Avatar
Send a message via AIM to Dustytheredneck
I've been searching but getting limited answers. so far, if I'm right, the coolant temp sensors on a '96 4.6l thunderbird is
driver side temp sensor is green and for the gauge
Passenger side temp sensor is grey and for the computer
what is this that I hear about a "cold start lock sensor" towards the rear of the passenger head?
also, on a '97 mark viii dohc - what are the two sensors under the intake?
thanks in advance
1983 F250 4x4 Diesel (summer daily driver), 1986 F150 4x4 strait 6 (plow truck)
1998 Lincoln Mark Viii LSC (Daily driver), 1995 Ford Thunderbird (Project)
1995 Ford Thunderbird 4.6 5 speed (sold), 1997 Lincoln Mark Viii (parts car)
Dustytheredneck is offline
post #2 of 7 (permalink) Old 04-28-2016, 06:04 PM
bowez's Avatar
CELO is for the heat (SATC system), its just a bi-metal switch.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #3 of 7 (permalink) Old 04-28-2016, 06:20 PM
If you have satc, you have a metal line with a temp sensor in it that goes from the engine to the heater core.
It has one wire, grounds thru the engine, and keeps from blowing cold air when the fan selector is set to "Auto", for the cars with satc.
post #4 of 7 (permalink) Old 04-28-2016, 06:53 PM
The DOHC motors got knock sensors; one each side between the middle two cylinders in the valley of the block.
post #5 of 7 (permalink) Old 04-29-2016, 05:29 PM
I wonder if their eec's response to a knock is better than our eec's?
Ours, if enabled, is severe.
post #6 of 7 (permalink) Old 04-29-2016, 06:54 PM
The Mark? I dunno really, I've never datalogged it to see the difference in timing between fuels. I probably should though, it does sound rather interesting to observe...
post #7 of 7 (permalink) Old 04-29-2016, 08:18 PM
The only time I get knock is on really cold, dry mornings.
It's only at ~40-50% throttle; I rarely drive in that regime long, lol.
The mbe2 eec I tried it on rolled ~10 degrees out quick, at odd times.
