What's this for? - TCCoA Forums
 3Likes
  • 1 Post By T6Rocket
  • 1 Post By jco1385
  • 1 Post By XR7-4.6
post #1 of 22 (permalink) Old 05-19-2016, 12:28 PM Thread Starter
What's this for?
I was replacing a bulb on the passenger side of my 94 and found what looks like some type of vacuum pump or similar. I was laying on top the wires for the headlight. It was not attached to any hose. http://imgur.com/gallery/qlT82tH
drew96dawg is offline
post #2 of 22 (permalink) Old 05-19-2016, 01:01 PM
Looks like the purge valve. The line to it probably rotted and broke off. You throwing and codes?
post #3 of 22 (permalink) Old 05-19-2016, 01:08 PM Thread Starter
No codes. I've only had this car about 2 months but it hasn't thrown any codes in that two months
post #4 of 22 (permalink) Old 05-19-2016, 03:29 PM
T6Rocket's Avatar
Check engine light may be burned out. You should have a code for that. Hell, if you fart near the EVAP system, or don't tighten the gas cap to 40 ft/lb, it will throw a code for 2 months. Touchy damn system for sure, not just T-Birds.
Al
CDsDontBurn likes this.
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #5 of 22 (permalink) Old 05-19-2016, 03:45 PM Thread Starter
Al
The light comes on before I start the car so I know the light functions. I haven't looked into it farther than that. How could I confirm that it is functioning correctly?
post #6 of 22 (permalink) Old 05-20-2016, 09:27 AM
jco1385's Avatar
That is for sure part of the EVAP system. The canister is right there behind the bumper support. All of my rubber hoses were rotten. I'm not sure about why it's not throwing a code though.
Part #4 in this drawing.
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #7 of 22 (permalink) Old 05-20-2016, 12:31 PM Thread Starter
Thanks for all of the good info. I'm still stumped as to why it doesn't throw codes. The cats are crumbling apart from age I figured that would throw a code of some sort as well.
post #8 of 22 (permalink) Old 05-20-2016, 01:35 PM
The 94/5s don't have the flow sensor like the 96-97s do so that could explain the lack of codes. What baffles me is the lack of second port on the purge valve, one port goes to the intake, the other to the charcoal canister/fuel tank.
post #9 of 22 (permalink) Old 05-20-2016, 01:41 PM
jco1385's Avatar
Where is the flow sensor on the 96-7? That diagram is from the 1997 FSM. I think the other side of the port may be broken off on OP's part.
jco1385 is offline
post #10 of 22 (permalink) Old 05-20-2016, 02:05 PM
It's not in it, the sensor is directly next to the purge valve, on the intake side, on 96-97s.
By the looks of it that image was simply reused between the 94 and 97 FSMs, and that addition was simply overlooked. The coil pack location, FPR placement, and wire harness layout are all specific to the 94/95 in that image.
post #11 of 22 (permalink) Old 05-21-2016, 06:46 PM Thread Starter
Would this have anything to do with my 1500 rpm idle?
post #12 of 22 (permalink) Old 05-22-2016, 11:30 AM
It being an open vacuum line straight into the throttlebody, yeah, it could do that.
Grog6 is online now
post #13 of 22 (permalink) Old 05-22-2016, 11:52 AM
I'd say it has everything to do with a 1500 rpm idle, yes
post #14 of 22 (permalink) Old 05-23-2016, 09:04 AM Thread Starter
I will pick up some hose and see if that valve was the culprit this afternoon.
post #15 of 22 (permalink) Old 06-04-2016, 09:34 AM Thread Starter
Update: i ran into some suspension troubles and had to replace tie rod ends, while doing so i attempted to put the EVAP system back in order. I found a small line between a metal line and a hard plastic line under the air filter. I replaced that, while fiddling with this i noticed one side of the purge valve is broken off. Can i still buy them from ford and try to get this fixed? The high idling has wrecked my trans fluid, im worried this stupid vaccum line is going to cost me a transmission.
post #16 of 22 (permalink) Old 06-05-2016, 05:07 AM
Looks like RockAuto has a Motorcraft for $42.99!
post #17 of 22 (permalink) Old 06-06-2016, 11:35 AM
And the lack of that sensor is why NJ wouldn't let a 1994/1995 use OBD-II to pass smog on the 4.6L. I asked. Now it is a moot point as 1995 and earlier don't get smogged at all.
steveg1988 is offline
post #18 of 22 (permalink) Old 06-06-2016, 07:57 PM
JoeyICU's Avatar
Thats funny because when I had my 94 in the early 2000s, MD plugged it in to'smog' it.
JoeyICU is offline
post #19 of 22 (permalink) Old 06-10-2016, 08:51 AM Thread Starter
Once i got the old valve off it threw code p0443 i got another valve and found its home. It helped a little, when i park the car it idles up to 1500 then back down to 1300. When cold it began at 950, slowly creeping up to 1300rpm at operating temp. Any tips on what to do next?
post #20 of 22 (permalink) Old 06-11-2016, 11:56 AM
Originally Posted by drew96dawg View Post
... Any tips on what to do next?
You still have a leak.
You need to do the cigar test; look for Ox's thread.
Grog6 is online now
post #21 of 22 (permalink) Old 06-15-2016, 09:08 PM Thread Starter
I seem to remember reading somewhere about water getting under the cowl and causing idle problems. we had a couple of dry days and eventually the car got to where it would idle correctly. when i got in this morning after a night time rain shower the idle is back to 1500. i dont know if this is relevant info to anyone, just my observations
post #22 of 22 (permalink) Old 06-18-2016, 06:49 AM Thread Starter
I developed a terrible miss over the last couple of days, yesterday i replaced plug wires because i had a set lying around. I also put a bead of silicone between the two halves of the wiper cowl. I will drive the car today to see if those two things helped at all
