Crank no start unless WOT. High idle. - TCCoA Forums
 7Likes
  • 1 Post By racecougar
  • 1 Post By Grog6
  • 1 Post By Thunderstruck95
  • 2 Post By donate12
  • 1 Post By thatglockguy
  • 1 Post By MadMikeyL
post #1 of 21 (permalink) Old 05-22-2016, 12:34 PM Thread Starter
donate12's Avatar
96 Tbird 4.6L. Well maintained. Ran great bit suddenly wouldn't start the next morning. Fuel pump primes (replaced fuel filter just in case), has spark, clean MAF and throttle body/plenum, intake aor temp sensor reading good voltage, coolant temperature sensor read 5V (replaced). Car starts with pedal floored. Idles up to 1800 before it feels smooth. Pull MAF connector and idle drops slightly. Pull IAC connector (on my third one in 10yrs), car dies. Ideas?
donate12 is offline
post #2 of 21 (permalink) Old 05-22-2016, 02:43 PM
Woodman's Avatar
Putting the pedal to the floor while cranking should disable the coil. That's how I would prime my remote filter (Fill filter with oil, fill pan, pedal to floor, crank 10sec to prime lines, then let off gas to start, oil pressure goes normal right away).
What kind of IAC are you using? If not Motorcraft, I've not had good luck with them.
Woodman is offline
post #3 of 21 (permalink) Old 05-22-2016, 03:08 PM Thread Starter
donate12's Avatar
Autozone IAC. Has worked fine for two yrs. Never got the harmonic resonance since. I do need to check it with a multimeter to be sure its good. Just discover a 2nd coolant temperature sensor. Guess I need to check it too.
donate12 is offline
post #4 of 21 (permalink) Old 05-22-2016, 05:38 PM
Woodman's Avatar
Coolant temp sensor won't cause a crank/no start.
I'd check the IAC. Yeah, the autozone ones (and all other 3rd party) work fine, till they stop. Motorcraft are the same, but they have more longevity in them. Not super expensive, about $50, and it'll work. Not sure it's your problem, but worth looking into.
Woodman is offline
post #5 of 21 (permalink) Old 05-22-2016, 05:56 PM Thread Starter
donate12's Avatar
Oddly I have seen and read where a coolant temperature sensor will go bad and read -20f when its more like 85F. Messes with other sensors. I.e. air:fuel.
IAC is reading 10.6ohms so within range.
TPS reads proper on two wires (brown w/ white=5.02V; grey w/white = 1.01 butterfly closed and 4.67V WOT). Hhowever, third wire (grey w/ red) reads 5.7ohms (suppose to be below 2ohms. Bad TPS.?.
All vacuum lines replaced 2yrs ago and look good.
donate12 is offline
post #6 of 21 (permalink) Old 05-22-2016, 06:41 PM
Woodman's Avatar
Possibly bad TPS. When mine went bad, I would get a high idle, high enough that the car would pull at lights, I had to be hard on the brake to keep it still. Similar to your issue. I replaced the TPS, that didn't fully fix it, so I replaced IAC, and hasn't been a problem since.
Give it a shot.
Woodman is offline
post #7 of 21 (permalink) Old 05-22-2016, 08:27 PM
WOT while cranking places the EEC into "clear flood mode". It disables the fuel injectors, not the coils. It sounds like you may have an injector driver hung open.
Woodman likes this.
post #8 of 21 (permalink) Old 05-22-2016, 10:23 PM
Woodman's Avatar
Thanks for the correction!
Woodman is offline
post #9 of 21 (permalink) Old 05-23-2016, 10:01 AM Thread Starter
donate12's Avatar
Re-cleaned the plenum, TB, IAC, and EGR valve last night. No change. Checked the impedance on each injector this morning. All were within 15.1 - 15.2 ohms (aftermarket injectors). Started easily and scoped each injector. All were cycling. Idled down to ~800rpm. Shut it off and started immediately with no pedal touched. Idled down nicely! Will test drive it and see how it acts today and report back. Stumped on what fixed it. Dirty injector connection.?. Loose connector.?. Who knows. But for now it runs "right"!
donate12 is offline
post #10 of 21 (permalink) Old 05-23-2016, 02:42 PM Thread Starter
donate12's Avatar
Well no luck. By the time I got around to test driving it, it is back to doing the same thing. Though the injectors all tested fine, I can smell gasoline on my dipstick....
donate12 is offline
post #11 of 21 (permalink) Old 05-23-2016, 06:33 PM
Woodman's Avatar
Bear in mind the injector/iac/tps can all test ok, but there is something intermittent causing the issue. It's not "all the way" broken, just intermittently. My IAC and TPS would only act up after hitting a bump in the road.
Woodman is offline
post #12 of 21 (permalink) Old 05-23-2016, 07:03 PM
Check the main harness rubber feedthru grommet at the firewall, on the passenger side.
If it's loose, the wire bundle is laying on the edge of the metal firewall, shorting out random stuff.
Woodman likes this.
post #13 of 21 (permalink) Old 05-23-2016, 08:07 PM
Thunderstruck95's Avatar
I am still thinking it's a hung injector. You could try unplugging the injectors one at a time while it is idling high to rule it out.
Woodman likes this.
1995 T-Bird.
PI 4.6. Bullitt intake. Stage 2 MHS cams. Kooks Headers. 4,200 ATF Speed converter. BCA Transmission. 4:10s. Tune by Supercoupes Unlimited. 245 RWHP.
3,700 lbs at half tank. Goal- 3,400 lbs
Best of 13.85 at 96 mph. Goal- 11's NA
1997 Lincoln Mark VIII FX2 Sand Dune Machine- R.I.P.
Thunderstruck95 is offline
post #14 of 21 (permalink) Old 05-24-2016, 12:51 PM Thread Starter
donate12's Avatar
First off, thank you all for the ideas/advice. I'm exploring all of them.
Wire bundle on the passenger side firewall seems fine.
Unplugged each injector and nothing changed.
Car started right up this morning but after 10min of driving, high idle returned. While standing on the brakes I got it home. Listened to each injector and was cycling fine. Unplugged the IAC and car died immediately. An indicator? Tried to jiggle the TPS and connector. Nothing changed.
donate12 is offline
post #15 of 21 (permalink) Old 05-24-2016, 03:51 PM
T6Rocket's Avatar
I would check the main harness like mentioned above, then pick up a Motorcraft IAC.
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #16 of 21 (permalink) Old 05-27-2016, 02:00 PM Thread Starter
donate12's Avatar
Pulled the fuel injectors yesterday and cleaned them. Car started fine and idled nicely. Test drive was smooth and a noticeable increase in power. Drove it again today and still seems fine. Good call on the stuck fuel injector. Now to get an oil change. Thanks for all the advice/suggestions. The old bird lives another day!
Woodman and Tbird Bob like this.
donate12 is offline
post #17 of 21 (permalink) Old 05-30-2016, 05:21 PM
HOw did you clean your injectors?
I think I may do that too.
Woodman likes this.
thatglockguy is offline
post #18 of 21 (permalink) Old 06-07-2016, 09:21 AM Thread Starter
donate12's Avatar
Well it is doing part of it again. Ran great for a week. Sat thru a tropical storm yesterday (good ole Florida). Now it idles high and drives itself. TPS is my guess.
Cleaned the injectors via the carb cleaner and pulsing method (9V). Vids on youtube.
donate12 is offline
post #19 of 21 (permalink) Old 06-12-2016, 08:01 PM
Moderator & Teksid Whore
guitar maestro's Avatar
I once had this happen. Oddly enough, was some kind of glitch on an auto zone IAC. I did a PCM reset, and it fixed it.
Get a code scanner that can see live data streams off the OBD-II connector. Look at the IAC duty cycle, commanded RPM, engine RPM, TPS Absolute, and TPS relative. Also look at coolant temp, battery voltage, maf counts/voltage. Of course this is what I would do.
guitar maestro is offline
post #20 of 21 (permalink) Old 06-13-2016, 07:15 AM
A stuck open injector, or a bad TPS will not cause the idle to be that high. You have too much air entering the intake, which means either a very large vacuum leak, or a sticking IAC. Since you said it intermittently fixes itself, and that you recently replaced all the vacuum lines, that tells me the IAC is the problem. Replace it with a Motorcraft part, and your problem will go away.
Woodman likes this.
post #21 of 21 (permalink) Old 06-15-2016, 04:44 PM
Sounds like water is dripping on your TPS sensor. It happened to me last year if there was a day or two of heavy rain. I swapped out the sensor for a dry one and built a "TPS Raincoat" out of duct tape to help direct water away from the electrical connector.
Now DOHC
StrmChkn4.6 is offline
