Fuel rail refurbish - TCCoA Forums
post #1 of 4 (permalink) Old 06-29-2016, 06:44 PM Thread Starter
ogbird95's Avatar
Fuel rail refurbish
So im swiching to bigger fuel injectors, lighting maf and scp cai and I thought it would be a good time to freshen up the fuel rail using the guid in the archives.
Thunderbird Fuel Rail
So is this the correct hose?
https://www.hydraulic-supply.com/com..._1/4_55642.htm
ogbird95 is offline
post #2 of 4 (permalink) Old 06-30-2016, 01:16 AM
KEVIN8989's Avatar
Its says 1/4 so I think it is the right one. I bet after those upgrades it should be a lot faster. Post some pics when you finish.
KEVIN8989 is offline
post #3 of 4 (permalink) Old 07-01-2016, 06:43 PM
Moderator & Teksid Whore
guitar maestro's Avatar
A properly functioning fuel system is not a restriction on these cars that came with 19 lb/hr injectors, unless there is a drastic change to the mass flow rate that the engine is passing through.
guitar maestro is offline
post #4 of 4 (permalink) Old 07-01-2016, 07:05 PM
My DA is putting dual-pattern 24lb injectors, a 2002 maf and inlet, and a new tune in a stock 96 with duals, an xpipe, and a pi intake this weekend, lol.
Can I use a slot maf with my eec?
EDIT: (I'm testing these parts for the dohc motor; they'll run, WITH A TUNE, but the injectors are overkill.)
Grog6 is online now
